Crucial info….. needs to be done...? (2004 Jag s, 191 000)
I bought my 2004 V6 Jag two moths ago. It has 191 000 on the clock. Just went for it's oil, filter, tyre rotation change, and it performs well.
All the dash board lights are off and apart from being a bit heavy on gas (7km per litre), No complaints!
I am just wondering, will the computer warn me if there is something crucial wrong/needs to be done? I remember years ago and in a different country when I had a Mazda, they told me the trick with that car is change the CAM-belt (or something like that) after 100 000 km! If you don't, the engine will burn out. And surely, it happened to a friend of mine that did not automatically change it but waited till there was a problem, then it was too late!
Now I'm wondering about my Jag, I don't have the previous owner's history, money is tight, but is there something crucial /I must get checked out apart from the yearly oil change?
Advice will be appreciated. Thanks!
NewJagOwnerInToronto (11-13-2013)
The following 2 users liked this post by JagV8:
JimC64 (11-12-2013),
The following 3 users liked this post by joycesjag:
Received 2,263 Likes
After doing what the guys have asked above and elsewhere (please....), download and study JTIS. Amongst many other tremendously informative bits of info, it contains the long term maintenance schedule for the car.
Figure out what should have been done in the past, deduct what has been done recently, that will indicate what's left.
The only things you really need to keep an eye on are the IMT O-rings (if they haven't been replaced with the updated green ones) Its in the "How To" here.
Keep in mind that all your vacuum lines under the hood are now very brittle if they are original, just looking at them wrong they will crack, the plus side is that codes will be thrown. IIRC to replace all vacuum lines it would run about $100.00 US if you DIY.
Since you don't know the history of the vehicle you might want to change out the transmission fluid, again found in the "How To" here.
Lastly switch out your fuel filter, guess where , its in the "How To" here.
Other than that it should just be routine maintenance.
BTW, nice signature!
Received 6,320 Likes
Thank you Rick (Joycejag)! I really appreciate this info. Now I just need someone that's handy that can do it for me, not a garage that will charge a million. I am very dangerous near a car's hood, I don't even know how to open it. Can anyone please help? There must be someone that ENJOY working on these cars as a hobby from their home that won't charge me an arm and a leg? I am also eager to attend a Jag enthusiasts get-together locally, there must be one somewhere locally in Toronto?
Rick (Joycejag) written: The only things you really need to keep an eye on are the IMT O-rings (if they haven't been replaced with the updated green ones) Its in the "How To" here.
Now you tell me lol! Should have warned me BEFORE I bought it…just joking, I...
These cars come WAY down in price as they age and seem like a bargain, but the cost of repair continues to climb as labor rates jump and parts start to get scarce.
Go to the regional Canadian section and ask about a backyard guy and they also talk about meet and greet on there.
Is the any chance you can do the repairs??
That's why the rest of us are here. I could never afford a 400HP luxury car if I did not do as much work as possible. I have a slight amount of oil leaking from my A/C compressor. To change the compressor and all the parts involved will be less than $300. I can afford $300 BUT I need to do the work otherwise the Jaguar dealer would charge me over a $1000 and that would just be the beginning.
And I have thoroughly read that fine A/C thread. But you guys are lucky because the STR is a SOB to work on. The front sub frame is much more reinforced and this really reduces the space to remove the P/S pump (Which I just replaced with a $60 Lincoln LS version) and the A/C compressor. Which by the way is also the same as the Lincoln V-8 compressor.
The packaging on the front end of the SC 4.2L is unreal with all the oil cooler hoses, intercooler hoses plus the SC belt. It’s possible but for a shade tree guy I am almost at my limit!!
Thang Nguyen
10-12-2015 01:25 AM
