Cutting off during acceleration
For the past week or so I started to notice that the engine tends to cut out when accelerating between 50mph - 65mph and RPM is around 1.5 to 2.
I don't have any Jaguar dealer close to me unless I make a 160miles round trip so I took it to a Ford dealer for diagnostics. They hooked up the computer and said they found two codes:
P1582
P0628
But nothing relating to the issue I explained. They asked me to come back later this week so they can diagnose it thru all day.
Especially when climbing the hill and i gently give it a gas to keep the same speed without being aggressive car jerks a little (dhub dhub dhub dhub) and then goes again almost like when you try to take a hill in higher gear.
I was due for an oil change so I did along with the air filter change and tire rotate and balance thinking ABS was taking a hold.
Where else and what could I look for because when taking off I used to get the hesitation within 5 - 10 mph hr which seemed to be fixed after I did a 100K maintenance which included the spark plug changes, but this new cut out kind of thing is getting me worried.
P1582
P0628
somedude (11-21-2012)
Received 2,191 Likes
before the 100k miles service it did have the misfire code this was read almost 6 months before i performed the service ,and wouldn't the code be register if it was a misfire or coil going out? How would i go about checking the fuel pump. I don't have any tools like the obii to hook up and check anything the codes o i provided was from the service tech from ford dealerahip
sorry for the grammatical errors or poor formating i am using my phone to answer
Misfires are flagged if the PCM can see them clearly enough, which is a big challenge for it. Brutal does tend to be right y'know...
Could clear the codes and see which if any come back soon. If you keep getting P0628 then it's probably a real fault.
On jaguars that show misfire counts for each cylinder, youll get 1000's of misifre counts without a code or check engine light. Youll be able to feel at idle or on accel, but without being able to read counts you have to wait for a cylinder misfire code to set, otherwise youre pissing in a fan. I regularly hear this complaint from customers and no codes. And if im working on a car i can see the misifre counter i know what cylinder is doing it, and i regularly see counts of 6,7 or 8000. Trust me youll feel a engine miss when it does it a few hundred times on accel, even at idle youll feel everyone. Add those up. So your choices are wait to see the cylinder or replace them all.
I don't think I will be able to leave it at the nearby ford place until next Tuesday to clear the fuel pump code erase but till then can i look for something else visually or feel to narrow the culprit?
Sounds very like a problem I had last year. One of the coil-over units had broken down. First it was misfiring and showing the engine light briefly when driving in wet weather, and after a while it started doing that all the time. S-Types tend to suffer a bit with the coil units. There are six - three of them under the throttle body assembly, which of course is where my bad one was, so given that getting at them is a bit of a dose and I had a major service coming up, I replaced all three as well as the plugs. The three on the other side are very easy to change - just disconnect the little wiring plug, undo the retainer (a long-reach socket is handy here) and pop out. IIRC they're about $40 each?
Sounds very like a problem I had last year. One of the coil-over units had broken down. S-Types tend to suffer a bit with them. There are six - three of them under the throttle body assembly, which of course is where my bad one was, so given that getting at them is a bit of a dose and I had a major service coming up, I replaced all three as well as the plugs. The three on the other side are very easy to change - just disconnect the little wiring plug, undo the retainer (a long-reach socket is handy here) and pop out. IIRC they're about $40 each?
I've found this set of 6 ignition coild on eBay, being a noob I do not know anything about these, any help on weeding out the ones I should stay away from is much appreciated.
ADP GDG517 Ignition Coils Set of 6 60 1004 FD496 | eBay
Edit: I checked on Jagbits.com and it shows the part number that I need is C2S42673 and this listing on eBay has the same part number listed as compatible or replacement.
It certainly did.
Couldn't say. Personally I'd be happier using Motorcraft ones.
