Cyl 6 misfire not COP RESOLVED
Received 6,351 Likes
SWIMBO called me a few days ago saying the engine light was on, she got the codes checked at O'Reillys and they said cyl 6 misfire.
I was due home yesterday so ordered up a new coil, switched it out this morning and put in a new plug also, no change still a severe misfire and RP.
I'm getting P0306 P1314 P1316 & P0356
I'm thinking the wire from the ECM to the coil, and going to try and check that now.
Any other ideas?
Any other ideas?
Got the pins figured out finally and I've got continuity from all three coil connectors back to the ECU plug, so that's saying ECU to me, any other possibilities?
I also checked the other three wires back to the other two coil plugs and get continuity there so I'm assuming those are all good as they are common.
Dear Norri,
My experience with automotive controls is unless the computer throws a code faulting itself, the computer is typically fine. Expensive little buggers to swap for troubleshooting, unless you happen to have a known good spare. As you may have already guessed, I do not care to discuss how I know this...
Since you have already changed the coil and spark plug, and the associated wiring checks okay, you may be looking at a compression issue. Compression is one of the factors affecting the voltage required for a spark to jump the plug gap. Reduce the compression, and the voltage required also drops dramatically. I'm not sure exactly how the system monitors the ignition primary and secondary circuits, but in my little world, it seems entirely plausible that a plug that fires too easily (the arc doesn't have to overcome normal compression) could be misinterpreted and mistakenly flagged as an electrical fault.
Of the 4 codes you listed, only P0356 is what I'd call a primary fault. That's a fault of the #6 cylinder primary/secondary circuit. (Wish I knew exactly what triggers the code.) The other three codes are secondary codes. P0306 = misfire detected #6 cylinder, which actually means low power output from that cylinder, and not necessarily a spark-related misfire. More details from my MisfireSoapbox™, partway down on this thread:
https://www.jaguarforums.com/forum/s...firing-146818/
The other two codes are for a misfire strong enough to cause catalyst damage. To troubleshoot any of the three secondary codes, the manual refers you back to the primary code.
I'd suggest running a compression test to be sure. It doesn't cost anything except for your time. Either you'll find a fault and then know how to proceed, or it will pass with flying colors and you can point out what an idiot I am. Either way, you win!
The only gotcha you may encounter is a weak or broken valve spring. It's possible for the valve to be blown shut during a low-speed compression test, but still manage to stick open at normal engine speeds. I'm not sure how to troubleshoot that scenario.
Norri (09-27-2015)
Is the #6 coil actually firing????
You can remove it and inserted a spark plug with a ground lead/wire clamped to the plug body to ground it. Lay it on the engine somewhere still connected to the harness. Start the engine. The plug should spark visibly.
If not then I would suspect the ECM.
I have an old spark plug with a small hole drilled/threaded in the hex area. I attached a wire with a small a alligator/crocodile clip for grounding that I use for this purpose.
Here is a pic of one I found on the internet that someone cobbled together.
bob gauff
bob gauff
Norri (09-27-2015)
Uffda, good point! Any chance of the new coil or plug being bad from stock? This is a troubleshooter's nightmare and is fortunately very rare, but it can happen. On another car, I once got a defective distributor cap, only allowing a weak spark to one plug. It fired a test plug okay, but still caused rough running when everything was put back together. It took some serious headscratching to figure out the new cap was defective. I took it back and got another but the rough running continued. I was really stumped until I realized the replacement cap probably came from the same defective batch. I purchased a third cap (different brand, from another store) and then everything was fine.
Forgive my ClavenMoment™ there. I'd suggest swapping the plug and coil with adjacent known good parts and see if the problem follows. Fortunately #6 is on the easy side to access.
Thanks for the ideas guys, I had thought about checking spark and compression but got kind of side tracked on the ECU idea after changing the coil and plug and checking the wiring out.
So this morning I rigged up a test with the old plug and an old coil I had and it did spark!
Pulled out all the plugs and checked the three cyls 2,4 & 6 for compression and got 195,195 & 200 so all good there, BUT, I couldn't get the new coil out of the cam cover hole and had to smash it up to get it out, so I boxed it up again with the another new coil on 2 and switched one of the used ones into 6 and it seems all good now.
I cleared the codes and have driven about 30 miles with a few shut downs and restarts and no codes so far.
Jon89 (09-27-2015)
Received 2,194 Likes
without reading through every post but to answer you from pm Norri. P0356 is the driver circuit for the coil. It will ONLY (coil verifyed not the issue) the wires or the ECU. unplug ECU and check the wires for that circuit from the ecu to coil for high resistance, open, cross short or short to power ground. If thats ok send to a rebulder for repair of the driver in the ECU............later
The following 3 users liked this post by Brutal:
LilaJagHubby
10-06-2015 02:56 AM
