Cylinder 1 missfire
Hello all, it has been awhile. Had my check engine light come on so took it to get it read and it is a cylinder 1 missfire, now Im not sure which one is cylinder 1. I was told to check the wires and coils but I don't know which ones to check, so if anyone can help me outi would be very greatful, thank you
Dan
Dan
Received 6,310 Likes
Just a reminder, any OEM parts that are needed, give Nalley Jaguar in Atlanta a call. Free shipping with oreders over $75.00 and a 15% forum member discount. I have used them and other members too, nothing but grand reviews!
As club mentioned, consider vacuum lines, rubber elbow, intake seals (upper and lower), IMT O-ring (if applicable) etc....
Oh boy......
There are 2 valve covers, one on each side of the motor. Look where you would add motor oil into the engine after removing the oil cap (also known as the 710 cap).
The manifold gaskets, there are 2 LOWER intake manifold gasket and 6 UPPER intake gaskets for your model year vehicle. Both the UPPER and LOWER gaskets are located under the big silver thingy right on top the motor, in between the 2 valve covers.
Are you experienced in mechcanics?
This is debatable, some will say yes and some will say no. On a vehicle thats your age I WOULD! I would also have the valve cover gaskets on hand as well, you can always return them if there are no signs of leakage as mentioned prior.
Any of the BIG box auto parts stores should have the gaskets in stock, I would check around more.
