Cylinder #3 Misfire Help
First, let me give a little history on my car: '03 3.0...I had lean codes for both banks earlier in the year. I knew my IMT o rings were leaking, so I went the long route.
While I had the intake off, I decided to go down to the cam covers. Replaced spark plug boss seals, cam cover gaskets, new plugs and coils, and new green upper and lower intake gaskets, imt o rings, TB o ring, cleaned MAF and TB, new brake booster and fitting, all sequence tightened and torqued as per JTIS...
Test drove car, seemed ok, but felt a slight roughness at idle, no codes.
Seemed to get worse as car idled.
Checked long and short fuel trims hot, at idle and at 2500 rpm, looks good.
Took out for a ride another day , got the flashing MIL! light went out, went immediately home, then the MIL stayed on for the above codes.
I swapped a coil for one of my old ones, same engine stumbling. Checked coil plug wire plug,supply voltage good, ground resistance ok.
Any ideas now what it would be? Im not thinking ECM, because I didn't get any trigger codes, which is why I didn't check the other two pins ( 4 pin coils). Hopefully I didn't disturb the wiring harness performing above work.
Also, spark plug well is bone dry, no oil.
Time is short, and its getting chilly here. Any ideas would be greatly appreciated before its off to the local indy shop! Sorry for the long post, I wanted to give all details.
Thanks for any input!
Yes, its a 2003 S Type, 3.0 base model.
I didn't have much oil, if at all in the manifold.
STFT's were fine,
Even though I put a new set of plugs in when I did the above work, I figured why not change the new plug again, although I thought it was a long shot, what were the odds of one being bad, new, out of the box?
Well, I swapped my new plug out for an even newer one. I put my new coil on plug back in, cleared my MIL from last time, started the car up, she ran great!
Took it on a 40 mile test ride yesterday, and 35 miles to work this morning, no MIL, runs smooth.
Who would've thought it was a new, bad spark plug. I'm still in disbelief, but whatever works!
franksm
12-27-2023 06:48 PM
Avro RJ
11-30-2015 07:40 AM
