Cylinder head gasket replacement info
Before leaping into major repairs, a step-by-step diagnosis would be a good thing:
How to Find and Repair an Automotive Engine Blown Head Gasket (2carpros.com)
kr98664 (09-30-2021)
Thanks, Dave, for the information
Below is what happened and my checks
· When accelerating from an intersection the engine sputtered and went into Restricted Performance mode.
· Looking out my rearview mirror a large cloud of smoke coming out the driver’s side exhaust.
· Low coolant message came in
· Pulled vehicle over, stopped and called tow truck
· Once back home started engine and again large cloud of white smoke coming from driver’s side exhaust. Nothing from passenger side.
Following checks carried out:
· Confirmed coolant level low
· Code reader showed misfire cylinders 2 and 4
· Added coolant to normal level
· Checked oil on dip stick and oil cap no evidence of milky goo
· Did a chemical check. Lots of bubbles in chemical test device. Chemical change color to an off yellow
· Did a compression test on cylinders 2,4,6 and all normal 120 psi ????
I plan to get a cooling system pressure tester next week and do a pressure test on the system.
Would appreciate and comments
Keith
Keith
Received 2,678 Likes
