DCCV or CCM
DCCV or CCM
I have the same problem with no heat. I find it interesting that you mention the signal being pulse width.. I ran a constant ground to either of the outer pins on the DCCV but made no difference. Maybe mine is stuck shut. But I have been wondering why there's no ground feeding from the CCV
Regards
Chris
Received 6,320 Likes
I'd assume that he means you were not providing a command from the CCM when testing the valve, so if your valve is toast when you tested with an independent supply / ground you need to change it, if you still have no control the CCM may also be faulty.
mel
09-20-2015 04:56 PM
OkieTim
09-08-2015 04:48 PM
