DCCV electrical coonector
Hello
i am finally lookign at the DCCV and have separared all hoses.I have pulled the red cover uback from the electrical connector but cannot figure out how to release it.I am supposed to push on something than pull the connector at the same time?
Help.
Thank you in advance.Fitz
Help.
Pull the red tab up. I believe there is a clip (I think the clip was under the red tab you can get to it after the red slide is raised) you have to push in on the clip while pulling up on the plug. I changed mine out a couple of weeks ago. The DCCV electrical plug was a pita. What I done; unbolted the DCCV after removing the hoses and got it as close to me as I could get so I could examine it.
Also I think I checked my replacement DCCV to see how the plug was clipped in.
I hope this helps? What was your DCCV problem?
Hello
Help.
Help.
Take care,
George
2002, cli, connection, connector, dccv, electrical, jaguar, plug, problem, remove, removing, replacement, stype, type
