dead battery 2000 s type v6
I have a problem with the battery going dead every couple of days. I have traced it to the radio/cd player. I have pulled those fuses and the problem has stopped. The radio worked, until I pulled the fuses. I was told that this is common and it is probably a defective amplifier located between the two rear speakers on the rear deck drawing current when the ignition is off. Does this sound right ?
Thanks, Bruce
Thanks, Bruce
put the fuses back in and unplug the rear amp, access via trunk, and see if you still have a drain, then you will know if it is the amp or not before spending money.
A few common battery drain problems are, lights in the boot staying on and the little flap not closing on the ignition barrel.
