Dead Battery, Trunk wont open, yes I tried the key. Help a Girl out!
UPDATE!! UPDATE!! I wanted to THANK each and every one of you that answered on this Thread. I also want to mention s couple interesting (to me, anyway) tidbits I learned:
1> The local Jag Dealer Service Dept told me I would not find a positive post to power the trunk in the passenger wheel well - You said they were wrong, and YES they were. I got the tire off, removed the liner and there it was. It allowed me to get enough power to the trunk to get it open.
2> I was able to jump start the car and I ran it for a while, then turned it off and back on. Tomorrow morning I will see if it has held a charge. A new battery is probably in the offing but that's okay as I know I can jump start it now.
3> A few things in the car are acting oddly now - like the Parking Break Fault Indicator is on for no discernable reason and the radio is on but no sound..but I think I read that weird stuff will happen upon re powering a dead battery so Im not too worried. I will figure out the stereo tomorrow. hopefully.
All in All a very successful day, Im leaps and bounds ahead of where I was this morning and it's all due to YOU GUYS! Thank you, Thank you SO MUCH!
OK I love my jaguar....but I HATE the Jaguar designers today. I mean really - who makes the trunk access dependent upon the electrical system working and then puts the battery in the trunk, which......wait for it ....will NOT OPEN when the battery is dead!
Before you say "Use the Key" - Let me tell you that I have already tried the key and it wont open the trunk - a secondary problem which is adding to my frustration level today.
PLEASE Oh Jaguar Gurus!!! The local Dealer has been no help in answering the below questions - I swear Ive called Service 3 times and each time gotten conflicting answers! Im leaving having my baby towed 50 miles as a last resort. What's a girl to do????
The Car: 2004 S Type R.
I would love someone to be so kind as to tell me:
1. Is there a secondary positive post in the engine compartment which I can use to jump the car? Im not trying to fry my electrical system so Im not too hip on trying to jimmy a jump by using the fuse posts or whatever. I read online that there is a jump post behind the passenger wheel well liner, but the Service guy at the Dealer seems to think not. I also read that there is a post in teh engine compartment but again another service guy poo poo'd that.
2. Is there any way to get into the trunk, without the key (see above) when the battery is deader than poop? Ive no idea why the battery went dry overnight, but to not be able to get to it because I cant get the trunk open is driving me to consider beating the trunk lid with a golf club!
My single biggest issue at the moment is the trunk access - once I can GET TO THE BATTERY I can go buy a new one and convince my neighbor to install it for me. Yes, Im willing to bat my eyelashes and feed him dinner for free battery install - dont judge me!
Thank you SO much for any advice!
- Diana
- Diana
Rob2004XJ8VandenPlas (01-26-2014)
Received 6,307 Likes
Yes. Remove the passenger front wheel well plastic liner. Behind that you will find a large red plastic cap. Remove this and attach your positive jumper lead.
This is NOT required as the key will mechanically unlock the trunk. The key hole is hidden. Did you find it or are you pushing buttons on the key FOB?
The keyhole is completely hidden if you don't know where it's at!
Bad Cattitude (07-30-2013)
To those who asked - YES I have tried the key in the hidden trunk key hole; in fact Ive tried BOTH keys. I wondered if I somehow got 2 valet keys - but the Parts guy at the Jag dealer tells me that it's a MYTH about the green (valet) versus black (normal) keys - he says the difference is a small divet cut in the head of the normal keys; that's all. He says the green keys were simply an older style...who knows, either way in my case I have two keys, one green and one not and neither is opening the trunk.
I bought the car and never tested the key in the trunk (bc I used the fob or button, right!) and so just found out the hard way that my keys wont open it (altho they do open the door key hole).
I am advised today to call a locksmith and if that doesnt work to have the back seat removed. Jaguar Service of Bellevue SWEARS that there is NO battery prong in the engine or in the passenger wheel well in this model. Not that I totally trust them. lol
There's a couple of options here https://www.jaguarforums.com/forum/s...ng-port-87362/
I would say no, the risk is really no different than if you were to hook up the jumper cables to the battery itself,
Once you have the jumpers hooked up to that spot, you're not even starting or cranking the car and even come close to frying anything important,
you'll hook up the cables, pop the trunk, remove cables, access battery,
Otherwise...
In you trunk, you have an emergency release handle you can pull in order to open the trunk from the inside,
Using the ski-pass-through inside the cabin to access the trunk, see if you can find a way to reach far enough to pull it?
Otherwise...
Otherwise...
Otherwise...
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
Let us know how it turns out.
It sounds like you might have a somewhat viable option with the ski pass-through. I just wanted to comment that, though as I mentioned before about having an XJ8 rather than an S-Type, I find it fascinating what your dealer said about the green-headed valet keys being a myth. At least for the XJ8, the user manual and any other documentation I've run across specifically differentiate the keys by the head color (green being valet), and the whole idea of the valet key is that it won't open the trunk (though I know you have both and neither are working). Interesting. Might be something to look into later, after you accomplish the most important task of getting the trunk open! :-)
Received 2,263 Likes
Jumpin' Jag Flash (07-31-2013)
The following 3 users liked this post by tbird6:
I own a trickle charger (2 amps) that I can hook into the cig lighter; I tried this and blew the fuse on teh cig lighter. Ive bought new ones BUT - My (non jag) mechanic and a male friend said NOT to do this tho bc it is designed to put put amps, not receive them. So now Im nervous to replace the fuses and try again.
Also, correct me if I'm wrong, tbird6, but it's probably not even necessary to "jump" the car. In other words, just hook cables from another vehicle's battery and open the trunk (no need to actually start the other car) Very low risk, other than making sure you hook positive to positive and negative to negative.
![Talking](https://www.jaguarforums.com/forum/images/icons/icon10.gif)
Thats an S TYPE??? WOW - you are right - That doesn't speak well of Bellevue Jaguar Service Department. Ok maybe I just need to go coerce my neighbor into jacking up my car, removing the tire, etc. Man, this is gonna cost me a NICE dinner, not pizza. *hee hee*
By all reports, there *is* a power stud behind the right front wheelwell. And even if there is not, a jumper can be attached at the starter positive post by crawling under the car.
You do not want to jump start the car ... the point of supplying power is to be able to use the remote to gain access to the trunk, and then charge the battery while the trunk is open.
If the key spins without unlocking the trunk you may indeed have two valet keys. The difference between a master and service key is that the very tip of the key shaft is smaller on the master key. A service key can be converted to a master key by filing the tip down at the sides.
