Dead Battery, Trunk wont open, yes I tried the key. Help a Girl out!
Received 6,307 Likes
Ok, first, you have to only do what you're comfortable with, but here's what I would do. As you can see by this diagram of power distribution, the next stop after the "bulkhead power stud" (the one next to the wheel that has been the subject of conversation) is the generator. Seems there is nothing between the stud and the generator, and nothing between the battery and the stud, so you could attach there (given it is somehow reachable and attachable under the hood). Just throwing out less complicated ideas, in case you can't reach the "bulkhead power stud" without removing the wheel.
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/49693-dead-battery-trunk-wont-open-yes-i-tried-key-help-girl-out-stypepower.jpg?dateline=1375225280)
The following 2 users liked this post by BillDJohnson:
Louis McMahon III (03-28-2014),
SunnyDay (07-30-2013)
By all reports, there *is* a power stud behind the right front wheelwell. And even if there is not, a jumper can be attached at the starter positive post by crawling under the car.
You do not want to jump start the car ... the point of supplying power is to be able to use the remote to gain access to the trunk, and then charge the battery while the trunk is open.
If the key spins without unlocking the trunk you may indeed have two valet keys. The difference between a master and service key is that the very tip of the key shaft is smaller on the master key. A service key can be converted to a master key by filing the tip down at the sides.
![Dead Battery, Trunk wont open, yes I tried the key. Help a Girl out!-photo-1.jpg](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/49694d1480969188t-dead-battery-trunk-wont-open-yes-i-tried-key-help-girl-out-photo-1.jpg)
![Icon Deadhorse](https://www.jaguarforums.com/forum/images/smilies/icon_deadhorse.gif)
:-) Just make sure you double-check these things, because, as I said, I don't own an S-Type and, though it's possible many of the years are the same or similar schematic, it could be different. Google something like "s type power distribution pdf" - maybe add the year too. Hope some of this helps!
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
I wanted to THANK each and every one of you that answered on this Thread. I also want to mention s couple interesting (to me, anyway) tidbits I learned:
1> The local Jag Dealer Service Dept told me I would not find a positive post to power the trunk in the passenger wheel well - You said they were wrong, and YES they were. I got the tire off, removed the liner and there it was. It allowed me to get enough power to the trunk to get it open.
2> I was able to jump start the car and I ran it for a while, then turned it off and back on. Tomorrow morning I will see if it has held a charge. A new battery is probably in the offing but that's okay as I know I can jump start it now.
3> A few things in the car are acting oddly now - like the Parking Break Fault Indicator is on for no discernable reason and the radio is on but no sound..but I think I read that weird stuff will happen upon re powering a dead battery so Im not too worried. I will figure out the stereo tomorrow. hopefully.
All in All a very successful day, Im leaps and bounds ahead of where I was this morning and it's all due to YOU GUYS! Thank you, Thank you SO MUCH!
The following 2 users liked this post by SunnyDay:
Jumpin' Jag Flash (07-31-2013),
Mikey (07-31-2013)
#28
Received 2,263 Likes
You'll have to "recalibrate" the EPB - see HowTos - any time the battery is off or dead.
Over here you need to input the audio code but you should not normally have to do that over there. When you do it's normally (always?) because the radio's been set to the wrong region. If you have the touchscreen there's a bypass: press >> AMEM and PTY.
#30
Glad you got it sorted. As I was reading thru, I was thinking of my 9V memory retainer that plugs into the cig lighter to maintain preset stations and clock, etc while you have the battery disconnected. Then I got to Mikey's post. I'm still curious if that would work, may go home and try it on one of our S-types. You would have to turn the key on as the lighters aren't hot in "off."
Also curious how you blew a fuse with a trickle charger - thought they only provided about 2 amps? Lighter fuse should be well in excess of that? If Batt dead and you had lots of equipment turned on, and plugged it in and turned the key on...I suppose, but the device would still have to be capable of more than 2 A output...just curious, not criticizing..
#31
#32
The car started today like nothing had ever been wrong and I took it in and had the battery tested and the guy said the battery is as healthy as a horse. So, while somewhat puzzling that it died in the first place, I can only assume I left something turned on. Once I get the radio sound to work again I will be as good as new.
The most impressive thing to me is that the advice I received from HERE was vastly superior to the advice given me by the service department of the local Jag dealer.
#33
#34
Not necessarily. Have a look around the forum and you'll find a number of threads concerning S-Types draining their batteries while the owner sleeps soundly in his/her warm furry bed. One of the chief culprits is the ignition switch, though there are others. I fitted a 5W solar panel and BatteryMinder charger/desulfator to the 03 as it is my daughter's and she is enrolled in an institution of higher learning some 6 hrs drive from home - so limited amount of time for troubleshooting - I truly believe in her case it was numerous 5 min trips across campus at night only - but no problems since fitting the charger.
#35
#36
Received 9,007 Likes
#37
Here is a trickle charger from Jaguar that plugs into the lighter socket it is also sold under the manufacture;s name.
Battery Conditioner - US (C2P25122)
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/77924-dead-battery-trunk-wont-open-yes-i-tried-key-help-girl-out-c2p25122.jpg?dateline=1396023253)
Other Parts In This Group
Battery Conditioner
- Diagnoses, monitors and maintains the Battery at optimum levels ensuring prolonged battery life and reliability.
- Features integrated wiring and a dedicated DIN socket within the Loadspace area, providing convenience and ease of use.
Part Number:C2P25122FIND A DEALERPRINT
SHAREShare on facebookShare on twitterShare
Battery Conditioner
#38
Battery Conditioner
Battery Conditioner
Norri (03-28-2014)
#39
This is $179 USD from your Jaguar dealer
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/77928-dead-battery-trunk-wont-open-yes-i-tried-key-help-girl-out-c2p25122.jpg?dateline=1396024206)
Battery Conditioner
Battery Conditioner
#40
