Details on Win7 64 bit new install method & new JTIS21 S-Type archive
Hi Jim, I believe I have downloaded and followed instructions to the letter however I get the following message when clicking the .exe file in the Jaguar folder:
"C:\Users\McKee\Desktop\JTIS21 S_Type\data\startup.txt contains an invalid path"
What I find confusing is why it is looking for a path thru "Users" when there is nothing there? Cheers Dan
Hi Dan (member Porcupine)
The file in your C:\jaguar folder that you need to run is jjtis.exe - the jjtis.exe file runs and opens the Jaguar Shop Repair software (JTIS manual).
You may have a problem with the jjtis.ini that is probably located in your C:\Users\McKee\AppData\Local\VirtualStore\Windows folder.
Use the search term jjtis.ini and search your C drive - you may have multiple jjtis.ini files in different folders that can cause the software not to start.
Here are the first 5 lines in my jjtis.ini file:
[File]
StartFile=C:\JTIS21\data\startup.txt
DataPath=C:\JTIS21\data
DTCStartFile=DTCStart.PDF
Whatsnew=C:\JTIS21\data\whatsnew.sgm
Here is what is in my C:\JTIS21\data\startup.txt file:
<!DOCTYPE STARTUP PUBLIC "-//JAGUAR//JAGUAR STARTUP DTD//EN" [
<!ENTITY JAGPICT SYSTEM "GRAPHIC\XK8CONV.BMP" NDATA BMP >
<startup><illus id="JAGPICT"></startup>
All the lines of code in the startup.txt loads a image of the jaguar logo (leaping cat) it will show when the software open its first viewing screen.
1st line is referring to the file in C:/Jaguar/Dtds folder (Startup.dtd) - it contains processing information about the image -
<!ELEMENT STARTUP - - (ILLUS) >
<!ELEMENT illus - - (#PCDATA)>
<!ATTLIST illus id ENTITY #REQUIRED>
I not trying to make you a programmer, but I thought I should explain how it works.
Jim Lombardi
[File]
Jim Lombardi
Somehow, the .ini file automatically installed "pointed" to my Users etc folders? I edited the file to read the same as your first five lines and lo and behold, I can now access all the files thru the .exe command. Thanks for for guidance.
Cheers Dan down under. PS: wonder why LHD has heater bleeder valve but not RHD? anyway I'll leave that question for another day.
I did not see the note here about the windows 8 msu and used the Win 7, seems to work, I had to do it through DOS! I can't believe I remembered DOS commands, geekdom, anyway it seems to be working, I'm a little hesitant to run the new software help and screw it up. And I had to make sure I ran the command prompt as admin.
Guys,
I have found an easier solution... Resurrected an old Vista laptop andloaded it up without a problem...
Can I just say thanks... I have spent the last week reading up on all the problems / solutions / tricks and tips for my new car and reakon you have saved me from making numerous mistakes, saved lots of $'s and given me some great ideas...
Thanks!!
Cheers,
Thanks!!
Cheers,
#28
devinda77 (08-20-2014)
Sunspit & JagV8
I just tried the mediafire JTIS archive downloads for S Type and also found that mediafire issue (blocking exe file type downloading) when I tried it with Internet explorer also with google chrome.
Update 7/7/2014 - problem with downloading these archive files on mediafire.com - instead use dropbox.com weblink
https://www.dropbox.com/sh/tfzpw26tv...w97SJQCyGMtOLa
I also added this update to post 1.
Jim Lombardi
Jim Lombardi
The following 2 users liked this post by jimlombardi:
Amadauss (10-24-2014),
Jumpin' Jag Flash (07-07-2014)
#34
That is the end. Jaguar switched to a subscription based repair access. Called TOPix. But for the S-Type not much changed from 2004 to 2008 when the car ended.
You can register and pay for TOPix if you want??
https://topix.jaguar.jlrext.com/topi...cle/lookupForm
#35
online website - jagdocs .com has s type workshop manual PDF file download updated thru 2010 ((3316 pages) for $11.86 US (£6.96 GB Pound) ($15.27 New Zealand dollars):
S-Type Workshop Manual - 2002.25 on [Jaguar S-Type STR X200]
Also Ebay - Jaguar S-Type 2001 - 2008 Workshop Service Manual 3500+Pages PDF and Electricals PDF file on CD shipped from UK to USA ($7.91; $4.82 plus $3.09) or shipped to New Zealand (GBP 4.87; GBP 2.97 plus GBP 1.90)
International mail delivery - Tue. Oct. 7 and Mon. Oct. 13:
Jaguar s Type 2001 2008 Workshop Service Manual 3500 Pages PDF and Electricals | eBay
Jaguar Topix for 2005 S Type weblinks:
workshop manual - webpage to request it:
http://topix.jaguar.jlrext.com/topix...x?groupId=1577
Topix login or register (need to be an independent repair facility):
https://topix.jaguar.jlrext.com/topix/user/loginForm
Topix registration terms webpage:
https://topix.jaguar.jlrext.com/topix/terms
Jim Lombardi
Jim Lombardi
#36
Thanks very much, I just bought the Jag Docs one. I'll take a look when I get chance to sort my in cabin temp sensor
Home | TOPIx
Jim Lombardi
Home | TOPIx
Jim Lombardi
#39
#40
S-TYPE06
Fixed weblinks in this post - 8/31/16 12:53PM
Here is workshop manual pdf for 2002.5 on S Type (covers years up to last production 2007):
https://www.dropbox.com/s/c4s7yfl9zy...anual.pdf?dl=0
full weblink - ignore leading xxx
xxxhttps://www.dropbox.com/s/c4s7yfl9zyzgxbp/2002%205%20on%20s%20type%20WSManual.pdf?dl=0
Used to be sold on vendor website -- website no longer active
dzb (10-25-2019),
Jumpin' Jag Flash (01-05-2017)
