Diagnostics Are Good! DCCV looks good. Still no heat... Help me out!
On the later (03+) cars, recirc pressed briefly (it willl beep once) means you only want recirc for a few mins then it cancels. To keep it on you must press and hold until you hear 2 beeps. This is in the handbook. Your era car may well be the same.
The various sensors have been covered in detail in previous threads.
Have you been to this site http://jaguarclimatecontrol.com/diagnose/ very useful information.
Good luck,
Nick
Good luck,
Nick
Received 2,192 Likes
With all this guesstimates youre wasting time. First theres not a fault with the dccv or the ccm, youve already verified proper operation. If the hvac sensor like the evap off or the driver and pass temp sensors are reading erroneously this can and will keep the heat off depending on what they read. I would replace them all , theyre not that expensive at about $30 each at a dealer if memory serves me.
The blend doors are supposed to default open to have heat if a system error or on shut down which is why after 15-20 sitting in the car with the ignition off you can hear the hvac unit "parking" the doors. I would have said a clogged heater core, but you do have flow on the pipes. The valves default to open on the dccv but can stick closed which doesnt seem to be your issue as already talked about. Replace the sensors, 2 on pass and 1 on driver sides of the hvac box, when you get the new ones youll see them if you dont know what youre looking at yet. THERE ARE READINGS TO PIN THE SENSORS AND CORRELATE TO TEMP, BUT I DONT KNOW THEM, I USE IDS AND READ THEM THROUGH THE CCM, IDS ALSO LETS YOU OPERATE ALL THE DOORS AND MONITOR THE DOOR POSTIONS ON SCREEN. SOMETHING THAT A DIAGNOSTIC FEE IN YOUR CASE WOULD BE WELL WORTH IT INSTEAD OF ALL THIS WHAT IF'S AND MAYBE'S.
BUT LIKE I SAID JUST THE COST OF NEW SENSORS WOULD BE LESS THAN A DIAG FEE AND THATS WHERE I WOULD PLACE A BET AT THIS POINT
BugDoc (02-02-2011)
I agree with Brutal.
I had a similar issue, and changing out my 3 temp sensors cured them all.
2 on the driver side 1 on the passenger side. my car is an 03, this happened to my 02. I can go take pics of the sensors and post them if you like, the likely culprit is the evap sensor. so Ill post up a pic of the driver side.
BugDoc (02-02-2011)
Thanks for the direction.
#28
You are right. I could not seem to find them listed in the search on the JTIS either. I'll do some more looking. The only thing I see that looks like a sensor behind a little grill just above the ignition key. I cleaned it and I am not certain how to change it without removingthe dash. The grill comes off, but there does not look to be enough room to get in there to replace it.
Thanks.
#30
Picture of sensors and some info about where they are. I searched on cabin temperature sensor
https://www.jaguarforums.com/forum/s...sor#post215201
also
https://www.jaguarforums.com/forum/s...sor#post179682
also
#31
also
also
The only thing close is called a "In-Vehicle Temperature Sensor 82.20.03"
That sensor diagram looks like this:
![](http://img830.imageshack.us/img830/6793/invehicletempsensor.jpg)
Uploaded with ImageShack.us
But I cannot see that the JTIS indicates that there are three of them? It also gives these instructions for removal.
1. Remove the ignition switch lock cylinder. For additional information, refer to <<211.04>>
2. Disconnect the in car temperature sensor electrical connector.
3. Disconnect the in car temperature suction pipe.
4. Remove the in car temperature sensor.
Is this really the location of one of them? Where are the others? And what do I need to remove to get to them?
Thanks again.
#32
It's hard for me to use JTIS as I have to find somewhere to run Windoze ![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
Another thread, with some locations. I Searched for
discharge temperature sensor
https://www.jaguarforums.com/forum/s...nsor#post93857
#33
Well... I can see the two on the driver's side. But they seem to be in really tightly. Do you twist? Or what? Can I use a screwdriver to pry them out? Any other tips?
Extactly how do you disconnect the electrical connector? I don't want to break either part.
Thanks again.
Thanks again.
#34
BugDoc (02-05-2011)
#35
#36
Just a silly suggestion... Give Dan at Nalley a call... I would do what BRUTAL suggested and just buy all three...
BugDoc (02-05-2011)
#37
#38
Thanks Brutal. I'll be out there as soon as it warms up a little bit this morning. I really appreciate your help!
#39
I will take some picks before I take them out. They are not visible unless you really get down flat-backed on the floor in front of the driver's seat and twist your head to look up and over. They are on the wall of the center console (up under the dash).
Getting my 265lb frame up under there was a chore!
Oh..... keep your arm away from the chair raised to shoulder height as you fall into that hole on the floor or you will have MUCH difficulty actually getting your hand up to where they are to reach them.
But I will post some pics too.
#40
The other thing that has me being cautious is that when we bought the car about 3 winters ago, there was a melted "crayon smell" in the car. That's what all our son's friends described it as... It was really strong.
So I am thinking that something more than a sensor may have gone bad. I don't know if the PO had a kid that sent a crayola down the heater vent on the dash that sealed the mixer actuator door or what...
Since I live in Texas, we rarely use the heat side of climate control. This year (this last month or so) has been an exception. But last week I was riding my motorcycle and loving it!
With the help of you all, I know I'll get this problem resolved.
