Diagnostics Are Good! DCCV looks good. Still no heat... Help me out!
#61
But I would probably buy it.... IF the Jag parts guys could find it in their system.
It is not shown on the page that 01SType30 listed either... Got a name? Part number?
#62
#63
I just stumbled onto this site: www.oemonlineparts.com
and I have to say "JACK POT!!!!!!!!"
They have schematics and exploded disgrams so I can search for my own parts! (You can too!)
![](http://img837.imageshack.us/img837/4588/evapsensor.png)
The parts I am interested in right now are on this page:
http://www.oemonlineparts.com/partlo...layCatalogid=0
Sorry for the long URL. I have not figured out how to embed hyperlinks on this forum yet.
Anyway, they have the sensor I showed in the picture above (part #10) for $14.08 each. That is more like it! I will order three. They also have the "Air temperature sensor" which I think JagV8 is calling the "In-car Temp Sensor" (part #12) for $17.84.
That website is going to save me a lot of money! I'll be ordering some parts this evening!
#64
Looks like they use www.trademotion.com, as I think do
www.jpamporschejaguarparts.com
http://www.gaudinjaguarparts.com/par...?siteid=214626
www.jaguarpartscenter.com/partlocator/index.cfm
I'm puzzled by part #11 as it's name means it should be a sensor when as far as I can tell it's not (it's a tube with a cross-flow venturi thing on the far end, struggling to describe it sorry).
Prices are good.
Prices are good.
#65
#66
#67
Prices are good.
Prices are good.
The part #11 is not that much money. When you say venturi, that makes me think it is essentially what gets air flow past #12 by creating suction with the normal cooling/heating airflow through the AC/Heater Assembly. Is that what you are meaning? Have you been into that part of the system previously?
If I understand correctly from talking with both parts guys today, all but one of the blender motors (actuators) are in that AC/Heater Assembly (#1) which comes at a price of over $1000. The only actuator that can be purchased seperately is the recirculation blender motor (#9). And that one is for certain working on my S.
But I am REALLY starting to wonder if these parts guys were looking at anything more than what we have on those pages. BOTH of them said that the vehicle "appears to only have one Evap Sensor" which is exactly what is shown in that diagram...
Certain the Jag Dealer Parts people have more.... don't they????? Also, where did they come up with those prices they were quoting me? I do not get it!
#68
Received 2,192 Likes
#12= incar temp sensor, is really only used during AUTO hvac control and a seldom failed part
#10=evap temp sensor, this is the biggest failure for proper HVAC operation in both AC and heat
you also have 2 heater sensors. 1 on each side of the box to measure pass/driver heater core discharge temps.. Ill have to say they look just like the evap temp but IVe never paid attention on parts quotes if they have a diff number
#14=external temp sensor, front of the car
#13=solar sensor ontop of the dash..
like I said before I use Ids to monitor the temps as the climate control unit sees them.
on the names....I always ask for the "evap temp sensor" But I can tell you that Jaguar drives us nuts when in the workshop/wiring manuals they call a part 1 name, parts dept descriptions, and warranty booking call it something else....can you not call a part the same damn name from place to place....I meen how hard can it be
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
BugDoc (02-07-2011)
#69
Looking at the JTIS, It looks like all the sensor except for the solar sensor appear to be thermistors. There are 5 thermistors and 1 solar. 1-in car 2-LH discharge 3-RH discharge 4-Evap sensor 5-ambient sensor. I wouldn't be surprised if they were interchangable. I don't Know but you should be able to tell when you find them. At least they are 2 pin sensors that will vary in resistance in responce to the temperature.
#70
QUESTION: Can #12 be replaced without removing the dash? It looks too larger to get out of the hole covered by the pop-out grill (#15). Please let me know. Thanks!
#72
Based on this, I am going to order 3x #10 and 1x #12 (just to be certain). #12 is not too much more money and I want to be done with this project!
#73
Ah. I didn't know that the original car was different.
#74
electrical circuit diagram
or any such will get you the URL.
The guides are mainly PDFs you can get from jag's TOPIx site. Cheap but not free.
Guides such as:
Jaguar S-TYPE Technical Guide Sports Sedan Introduction 122pp
Technical Guide Jaguar S-TYPE Sports Sedan Powertrain Introduction February 1999 68pp
and there's a Training one (TSBE/99) which covers the entire car, 332pp
plus various on the PCM which probably won't interest you.
(These are just about the original car, there are others for the later model years.)
They have JEPC aka jag EPC. There's a recent thread about it and where to get it.
#75
this might help you with the blend doors and the part numbers for ech motor.
http://www.import-car.com/Article/73760/Tech_Tip_Q.aspx
#76
#77
#78
Bugdog
I had a similar issue, chkd voltages, resistance, chk the temperature of the lines, and finally, it was directing to the dccv. Luckily i live in CA, and heat is not a major issue.I decided, i will not spend any money or my time trying to t/shoot.
One day i had to use the defrost button(one below AC switch) ALAS, heat started to come from all the vents.I reckon as you said the blend doors must be the culprit.
as a last resort while engine is running why dont you try this switch and see if you get heat. good luck buddy. My car is 2000s V8.
#79
Two are easy to find and shown in the picture I posted previously. I have marked them with blue arrows in that same thumbnail photo shown below.
![](http://img689.imageshack.us/img689/2339/driversidetempsensorsan.th.jpg)
I don't think either of these is the heat blend actuator though.
One test I did do to trouble shoot was to try to run heat and AC without those two sensors in place. If these sensors are bad, you will get zero AC. It seems the compressor cannot even kick on if these sensors are not functioning. Once I reconnected the sensors, the AC worked fine. (I think that tells me that these two sensors are actually functioning correctly.)
That's not the problem I am experiencing. I have AC but no heat. But I thought I would post the observation in the event it might help someone else down the road!
I still need to break into the other side, behind the glove box. I did not have time this weekend.
Thanks for the continued suggestions. I will try the "Defrost switch" suggestion too.
#80
