Did I kill my ZF? 03 STR
Did you disconnect the battery when you serviced the gearbox because the codes relate to the voltage
P0560 system voltage malfunction.
Possible causes Low battery charge
Battery defective Loose or missing
Alternator drive belt Faulty alternator Op
Open or short system voltage circuit
P1643 CAN ECM / TCM Network Malfunction
Control Area Network (CAN) open circuit fault – TCM to ECM CAN short circuit fault Faulty Transmission Control Module (TCM) Faulty Engine Control Module (ECM
so start by checking the battery voltage etc. Then see if there is any battery drainage indicating a short circuit.
Check all the electrical connections that you moved or disconnected.
electrical faults can be very irritating to find the cause but as the car was running correctly before you serviced it. It will relate to a cable that you moved.
I was once disconnected the battery and when I started the car later everything was ok but 10 mins later when I tried to drive the car nothing worked. It was found to be the earth connection was not quite tight enough but it looked and felt ok.
Ok let's us try to deal with one problem at a time.
Check the battery change it has to be over 12.6 volts.
Open the JTIS program
press on the doc button.
go to + pxxxx press +
Obd
powertrain v6,v8 from vin m62936
press
Abode reader look for p0560
look at the monitoring condition.
You can also use the Obd scanner to check the voltage from the alternator.
Obd
press
Benji999 (03-05-2017)
Ok
Here is the next step for you as I will busy on Moneday.
open JTIS
go to service : set it for s type 2003
when open go to the bottum row of buttons press second from right (it looks like lines on a page.
open 4 elecrtical.
go down to 418.00 module communications Network
go to diagnose and testing
open communications network
scroll down to the DTC 1643
go to E press
and then follow the test
first assume that the TCM is working just do visaul test dont change
Slowly go through all the tests
Here is the pins in obdii
Connector pinout:
PS: It should be noted that the remaining pins may be used by the manufacturer as needed.
Pin no.Description1
2J1850 BUS+ (SAE)3
4Chassis ground5Signal ground6CAN High7K line (ISO)8
10J1850 BUS- (SAE)11
14CAN Low15L line (ISO)16 Battery +
open JTIS
open 4 elecrtical.
go to E press
Connector pinout:
![](http://www.outilsobdfacile.com/obd_presentation/obdii-connector.png)
Pin no.Description1
2J1850 BUS+ (SAE)3
#28
#31
Okay folks. I am kicking myself. It was the fuse! Something as simple as disconnecting the battery before performing any kind of work could have save me so much stress. I appreciate you guys and your help and suggestions so much. You don't know how relieved I feel right now.
I've still got some work to do under the hood -
•Valley hose
•DCCV
•Thermostat
•Belts
And I need to figure out where the oil that is getting on the belts causing them to squeal is coming from. But I am ecstatic right now.
Again thank you all
Benji
•Valley hose
•DCCV
•Thermostat
•Belts
Again thank you all
Benji
The following 3 users liked this post by Benji999:
