Did My First Oil & Filter Change Yesterday
Although I always have fun learning about working on a new (to me) vehicle the first time I crawl around underneath it, I'm still shaking my head about the wisdom of placing the oil filter in a spot where shielded hoses (I assume they are fuel lines) run directly underneath it. Couldn't remove the filter with my spanner wrench because there wasn't enough working room to use the handle to turn it. Couldn't use my filter removal cap attached directly to my socket wrench because the hoses were in the way. Finally decided to thread a 12-inch extension through the hoses, plug it into the cap, and work with my socket wrench a good 16 inches away from the tip of the filter. Distance leads to tool wiggle which leads to a greater chance of crushing the filter and causing the cap to lose grip and thereby making it very difficult to get the filter off.
Still love the car, but really despise this oil filter set-up. Even though I figured it out without having to buy more tools, it will still be a hassle every time.
Anybody out there have a better way?
Received 6,320 Likes
Lol you should see the setup on the 4.2.. the filter and drain plug are literally 6" away from each other and are right on the very bottom of the engine.. I timed my last oil change and it took me 9 minutes from start to finish. I always use Motorcraft filters and Mobil 1 5W-30..
How long are the rest of you going in between oil changes?? sometimes I only go 3k miles, but other time not till 5k of even 7k??? but this pig also takes almost 7 quarts so it gets kinda pricey to change it all the time..
On all of my cars, its 1/2 of the manufactures recommended interval. So for the stypeR, its every 5k miles with 0W30 and either bosch or factory filters.
7 qts is a lot but at least the 0W30 from mobil comes in 5 qt containers and available at Wal-mat for about $22. I have another that takes 9 qts of 0W40 that you can only buy in 1 qt containers from the auto part stores (9x$6.99) which gets really expensive and another that takes 7 qts of 0W30 but the interval is 3750 miles. So the Jag's not cheap but pretty reasonable for a modern car and 7qt seems to be the std with extended oil change interval cars.
FYI: Mobil 1 has a $10 rebate for 5qt starting from 4/1 on their website due to some weather related supply issues.
I did this first oil & filter change at a 6,000-mile interval. The service guide says to do it every 10,000 miles, but that's a bit extreme in my book unless you're running full synthetic which I don't. I'll change the oil every 5,000 to 6,000 miles just like I do with our two other vehicles. I'm sticking with Jaguar's recommendation of Castrol 5W-30 conventional oil. When it's on sale at Wal-Mart or Advance Auto Parts or Pep Boys, it's half the price of synthetic and it certainly protects my warranty, extended or otherwise. My 3.0 engine took exactly 7 quarts. I've used Purolator filters for decades so that's what I put in the S-Type as well. The old filter I removed was Jaguar - who makes it? I would guess Wix....
I would love more information on the Jaguar and Bosch oil filter. I was going to change my own oil, but after adding $25.00 for the filter, another $30.00 for the oil, and $5.00 for the plug. It is better to just go to the dealer and pay $75.00. I looked up a Bosch filter @ Auto Zone and there wasn't one listed for the 4.2 S-Type.
[quote=whiteSTR;104141]Lol you should see the setup on the 4.2.. the filter and drain plug are literally 6" away from each other and are right on the very bottom of the engine.. I timed my last oil change and it took me 9 minutes from start to finish.
9 minutes Eric?? I did mine in 8 1/2min. Lol J/k I go about 5k between oil changes... and yes I do have the dorky little sticker on my window to remind me. Contrary to what you may think (and I know you will all be shocked to know) I do NOT do my own oil changes. I also do not go to jiffy lube instead I let the dealership take full advantage of me and my wallet and have them do it! Don't you guys just love when the women on this site put their two sense in???
Wow uptown, I thought I was going to have to take you out to dinner and maybe even on a cruise.. I didn't know all I had to do was change your oil to be able to take full advantage of you.?.?.
Every 3k miles....... excessive............. yeah so,
Castrol only, figured since they sponsored Jaguar Racing I will be a loyal customer,
Castrol SYNTEC Blend
SAE Grade
Viscosity @ 5W-30
ASTM D-
100ºC, cst 445 - 11.0
ASTM D-
210ºF, SUS 2161 - 62.8
Low Temperature (ºC) ASTM D- 6600@
Cranking Viscosity, cP
max 5293 -30 -30 -25 -25 -15
Low Temperature (ºC) ASTM D- 40000@
Pumping Viscosity, cP
max 4684 -35
ASTM DSpecific
Gravity 1298 0.857
Pounds Per Gallon 7.14
Oil filter of choice
Bosch Oil FIlters - Bosch Premium Oil Filters, featuring Bosch FILTECH, utilize an exclusive blend of natural and synthetic materials to provide superior oil filtration and increased engine wear protection. The Bosch FILTECH filtering area is up to 42% larger than conventional filters. Plus, the filter media is close to 30% thicker, and can screen out more harmful contaminants than a conventional filter.
$3.80 a filter
SAE Grade
Viscosity @ 5W-30
ASTM D-
ASTM D-
max 4684 -35
ASTM DSpecific
Gravity 1298 0.857
$3.80 a filter
If my notes are correct its a Bosch 72209. Is $4.95 at www.autopartswherehouse.com I have also used the Beck/Arnley which is a rebranded MANN filter that is the OEM supplier for a lot of european cars (Porsche, BMW, Volvo, etc) with good results
My 03' Jag at the moment is giving me 25mpg on the Highway so far, so anyhow Please give your advice on the Air filter if the brand Cooper is any good?
Wes Steenrod
09-06-2015 06:52 PM
