Difference size tires f-r
Does anyone know if I would run into problems if I had different sized tires front to rear? In particular, I'd like to run 245/45-18 all seasons on the
front and 245/40-18 snows on the rear (about a 4% difference in circumference).
Will the TCU/anti-lock systems have any problem with that?
What about STRs they had different sizes f-r? But did the difference in
aspect-ratio make up for the tread width difference?
Oh, '08 4.2l
Jaguar: Grace, Pace, and Space - Sir William Lyons
Oh, '08 4.2l
No idea how much difference in diameter the car can tolerate without setting off the ABS warning.
The rear tires can be larger but I would not recommend smaller. The TRAC CONTROL 'might' assume that the slightly faster turning rear wheels need intervention and activate the TC.
When I worked at the dealer I had a car in for diagnosis (XKR) and the customer stated that the car would occasionally slow down on the hiway with the TC flashing in the INSTPK display.
It turned out that the customer had ROTATED the wheels/tires FRONT-TO-REAR and the slightly smaller tires in the rear were were enough to cause the TC to think they were losing traction!!
The rears can always go SLOWER but not faster (at least not by much).
I can't tell you that the ones you are referring to are enough different.
I don't know the exact difference that will cause problems.
bob gauff
bob gauff
FS[SouthEast]: Rain X waterproof car cover NEW
Sublyminal
09-03-2015 04:48 PM
