Differential
Differential
Greetings,
Change out my differential fluid yesterday. I am surprise the gears didn't grind or nothing. The fluid was very low and black. Very hard to pump out since it was thick, the plug had about a 1/4 inch of sludge stuck to it. The job was really easy and even had my daughter help.....daddy moment. The new fluid went in like a charm and believe it or not, that was my lurching issue. Thanks all and have a great day!
The following 4 users liked this post by desertchimera:
Jumpin' Jag Flash (03-03-2014)
Changing rear axle seal - done?
tx
Duke
It depends on which diff you have. Is it the Ford/Visteon 8" or the GKN diff?
You can see the difference in this thread, where the Ford/Visteon unit was removed and replaced with the GKN. https://www.jaguarforums.com/forum/x...97/#post960840
Seals are available as spares for the 8" but not for the GKN as far as I know...
I'm afraid oil change will not take away the diff whine. I'm betting you can sustain the whine around 55 - 60 mph with light to moderate load. If so, the oil is not the culprit, it's the internal bearings where preload is not correct and allowing the bearing raceway to resonate. I would love to be proven wrong on this however.
Checked with my indie - old oil sucked out while warm, refilled with new oil, car driven until warm, sucked out again, refilled again. I guess that's how he translated my request to 'flush'. 45 minutes labor.
I got the diff whine too. Obvious on accel/decel, quiet on cruise. Changed diff oil today with the Amsoil. Old oil was full of glitter, but normal viscosity and smell. Also, oil was completely full. Magnet on plug was completely packed with powder. Cleaned the magnet and replaced the fluid and the whine is significantly reduced. I'll clean the magnet again next week to see how it looks.
I'm looking for parts to put together an LSD assembly at my convenience. According to the info I see, a Ford 8.8" diff case should fit the stock housing on my car.
Woznaldo
09-26-2015 11:02 AM
