Ding, ding, ding....
![Icon Couchhide](https://www.jaguarforums.com/forum/images/smilies/icon_couchhide.gif)
Unfortunately, some nimrod used $3.00 worth of epoxy to cause this poor member of the forums to have to drop their transmission to fix it.
I'm not sure how easy the motor mounts are to get to but could you just remove or loosen them enough to clear the bolts from the tunnel to allow access? I wouldn't think you would have to lower the complete tranny but just enough to clear the floor board or beam that is there....
I will shake my finger at you on Sunday! Mainly for cutting and welding over a fuel tank / lines/ pump....Along with cutting holes in your car..![Icon Couchhide](https://www.jaguarforums.com/forum/images/smilies/icon_couchhide.gif)
All I can say is, trust me, I'm a professional. (professional what...well that is up for debate)
JOsworth (06-02-2011)
#30
#31
#32
#33
#34
#35
#36
I experienced the same issue with the shift lever stuck in Park position. I learned a couple things while troubleshooting that I either missed in this thread or that were not mentioned; the indicator light on the shifter will light the gear the transmission thinks it is in - not the gear the shift lever is in. If the indicator doesn't match the shift lever, you probably missing a bolt which fastens the shifter cable to the transmission as JOsworth called out initially and Joysesjag also mentioned (and provided an awesome pic). If the indicator is not showing the transmission is in Park, it will not allow the shift lever to come out of park, meaning you would have to remove the shifter cover on the center console and locate the lever that releases the shift gear from park.
As i mentioned, I was missing a bolt that holds the shift cable to the transmission. When I aligned the hole to oput the bolt back in, the transmission shifted into Park (where is where the shift lever was at the time). Use blue Lock-tite to prevent the scren from coming out easily - stay away from red lock-tite as it requires heat to remove the bolts.
#37
Yes, we've talked about this in many threads over the past few years.
Checking those bolts should be a regular part of doing (or having it done) an oil change. When the belly pan is removed reach up with a wrench (8mm ?) and snug those bolts. Then remove drain the oil.
Jaguar - it's not an automobile, it's a Motorcar
2015 JCNA National Slalom Champion Class M
Current: '08 S-Type 4.2 "Satin Edition" (250.06 whp / 259.67 torque)
Past: '05 X-Type 3.0/auto Jaguar Racing Green
