disable Drive Away door locking
ian.fox (11-20-2018)
Try the following.
This may work to deactivate the auto locking:
Turn on the ignition so all the dash lights come on but do not start the engine.
Lock the door using the button on the door handle and then unlock the door 3 times. (But do not open the door.)
Turn off the ignition.
Turn on the ignition but do not start the engine and you should hear a beep.
Lock the door then unlock it, once only this time, and you should hear a final beep.
The feature should remain deactivated until you repeat the procedure above to reactivate it again.
Do let us know how you get on.
Mellow
Mellow
ian.fox (11-23-2018)
toshy
08-04-2014 10:07 AM
