Discovered that tranny is leaking
George
The sleeve release is inside of the transmission so the pan needs to come out first; otherwise, it would be too easy and only a $12 fix.
1x Oil Pan/filter/gasket: $134/$143
21x Oil pan bolts: $2.67 each, you got dam lucky and got them for .39cents each
1x Valve body sleeve: $12.10/$16.04
If anyone knows a better place to get the Transmission Mount cheaper than $118 please do let me know.
Thanks to all.
Jag79 you might want to try ken@britishparts.com
BTW what is up with the europeans and their tranny fetish
#28
Its a Westar brand, says it OE direct replacement fit for my STR and S, but I have my doubts on wether its a good quality or not. I even called up Gaudin jagaur parts they wanted $91 OEM plus shipping charge of $12
....You gotta love them GIMP outfits those Trannys like to wear over in europe
..Hey bro I took my car in today at friends garage, we checked the sleeve it was completely dry. But the leak was coming from the drain plug on the bottom of the plastic pan. I'm guessing the washer has gone bad on the plug. NOw since my STR has 87k miles on it, I might as well change the fluid, fill plug, Sleeve, and get the complete Pan which includes the filter and gasket. Also found out that my Tranny mount is gone bad ,that part alone cost $118 from the dealer. I called up ZF distributors and they dont carry the Tranny mount. Also the ZF prices have gone up since the last time you purchased from them.
Thanks to all.
Thanks to all.
#30
Do you need the new bolts? If you have new one with the larger torx head, you can reuse them. I think the $0.39 was a typo, maybe they finally caught it. There is a Las Vegas outfit that comes up under the search for Jaguar Porsche parts that usually has pretty good prices for the Jaguar parts.
p.s by the way the sales rep at ZF distributers did say it was a typo and those who ordered it at that price they honored it,lolz...they finally did catch on
#31
#32
.....I have the Torx27 type bolts, but Im assuming those are the old OEM ones that they came standard. Can I use those on the new ZF pan if I order through them, or do I need to get the Torx40? or it doesnt even matter? lolz.....
#33
Had I been smart enough to find by set with a torx27 instead of torx25, I would not have stripped any of them. I seems like in places with harsh winters, the bolts may be more difficult to back out and one can strip the torx27. Being in Florida, it should not be an issue. I personally used anti-sieze on re-assembly and cut slots in the stripped heads to use a screw driver to re-assemble before the new ones arrived so I would order later if you need them. I can also send you a few old Torx27 if you need a few.
Thanks for helping out.
#34
Wow
I just got my car back from the dealer today. They put a couple of new oil rings in the tranny, replaced the tranny pan, and changed the fluid. They fixed my power rear sunshade that was stuck down as well. They also topped off the car's other fluids and checked my brake pad thickness. the total charge for all this was $20. I'm impressed.
Regards:
Oldengineer
Regards:
Oldengineer
#35
#36
Regards:
Oldengineer
Regards:
Oldengineer
Hmmm... I actually wish my sleve would leak..Great way to get some fresh fluid on the cheap with the warranty..
#37
#38
Yup..His dealer did what they are supposed to do.. To fix the leak they had to drop the pan. That basically gets you a trans fluid and filter service. The sleeve is internal, so it's covered.. They also did an inspection for him and I bet only charged him for shop supplies (any fluids they had to top off). That is the way dealers are supposed to do things....
That is also why my next car will come from my dealer...despite the body shop mess up..
#39
#40
Maybe catch some episodes of Top Gear
I mentioned them to Joyce, but she shot them down. "We" don't let the kiddies watch tv in vehicles unless we are on a road trip.
