DIY ~ S type How to pull out / remove your 4.0 Engine and Transmission HOW TO
Old 10-05-2012, 02:16 AM
JagV8's Avatar
Received 4,534 Likes on 3,943 Posts
Maybe JTIS clears up the issue on rads?
Old 03-13-2014, 04:23 AM
mgvdh2000's Avatar
Default Have you got the photos!?
Hi,
I'd love to see the pics for this, because I've got to do the same job! Any chance you've still got them handy that you could send?
Matt
Old 03-13-2014, 05:16 AM
GGG is offline
Received 16,860 Likes on 12,186 Posts
Originally Posted by mgvdh2000
Hi,
Matt
Welcome to the forum Matt,
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
Old 03-13-2014, 12:36 PM
tbird6's Avatar
I have posted this before but this thread is a great example of what NOT to do.
Wonderful post and many pictures which are all gone now. Why?
ALWAYS post your pictures directly to this list. If you use any hosting spot or other crap all the pictures will disappear whenever it crashes or moves and we end up like this one. Nothing but X's in place of all the pictures.
Old 03-13-2014, 10:57 PM
Tijoe's Avatar
At least I was able to read it and find that he pulled the engine and trans together. Something I was trying to confirm. too bad the images are gone, it makes the post almost worthless...
Old 03-16-2014, 02:55 PM
Tijoe's Avatar
The engine and trans does indeed come out the top....
Attached Thumbnails DIY ~ S type How to pull out / remove your 4.0 Engine and Transmission HOW TO-20140316_122743.jpg
Old 11-02-2016, 03:13 AM
JuodaKate's Avatar
Hi, i need help with engine change, who can help with photos?
  #28
Old 11-03-2016, 08:01 AM
x.l.r.8's Avatar
Firstly people post their progress with pictures as a courtesy, a free service, the appropriate response would be thank you for hard work and posting links to how you did the procedure.
Secondly there is nothing to demanding on removing the engine as long as you take the trans out with it. The radiators (all of them have to be pulled). You can take just the trans out but you have to be pretty crameative with extensions and wobble bars and u-j 's to get to the bellhousing bolts and the exhaust gets in the way. The engine comes out with relative ease the biggest issue being the plastic clips holding looms and the small breather pipes are super brittle. Disconnecting everything is no different from most cars. I swapped my engine out in a day, the second day I replaced the trans fluids, hooked the pipes and wires up. Oil and coolant change and I was done. I also deleted my pictures but most things are custom made, take pictures as you go, you can even steal the write up above and add your pictures into the text.
abonano (11-03-2016)
Old 11-04-2016, 06:43 AM
clubairth1's Avatar
Received 2,389 Likes on 1,884 Posts
Why did you delete your pictures?
Norri (11-04-2016)
BrentGardner
28
04-26-2024 03:08 AM
SatanClaus
US Southwest
08-31-2015 11:45 AM
stanjag
08-30-2015 10:35 AM
SatanClaus
08-29-2015 09:15 AM
SingBlueSilver
08-27-2015 02:20 PM
Quick Reply: DIY ~ S type How to pull out / remove your 4.0 Engine and Transmission HOW TO
