Is this a DIY job or best to have fitted?
Old 02-09-2011, 01:23 PM
bens's Avatar
Default More Wire's
Hope this help's
Regards Steve
Attached Thumbnails Is this a DIY job or best to have fitted?-100_1249%5B1%5D.jpg   Is this a DIY job or best to have fitted?-100_1250%5B1%5D.jpg   Is this a DIY job or best to have fitted?-100_1251%5B1%5D.jpg   Is this a DIY job or best to have fitted?-100_1252%5B1%5D.jpg   Is this a DIY job or best to have fitted?-100_1253%5B1%5D.jpg
Old 02-09-2011, 01:33 PM
androulakis's Avatar
Originally Posted by bens
Hope this help's
Regards Steve
That does help, alot actually.
Now in one pic, lay all the wiring out, side by side, and i'll give you a step by step on what connects to what.
Do those screens have DVD players behind the screen or no?
Btw Jeff, notice those are the actual S-Type headrests and not The oversized ones with the piping the north american market got...
I bet those dvd players are EU region coded though
Take care,
George
Old 02-09-2011, 02:26 PM
bens's Avatar
Default More Pic's
Yes the headrests are the same size and no pipeing, and this is a stand alone system no dvd players.
Regards Steve
Attached Thumbnails Is this a DIY job or best to have fitted?-100_1255%5B1%5D.jpg   Is this a DIY job or best to have fitted?-100_1256%5B1%5D.jpg   Is this a DIY job or best to have fitted?-100_1257%5B1%5D.jpg
Old 02-09-2011, 09:01 PM
Ok here goes:
Basically here's what you have to do.
First you need to remove the front cigarette lighter plug.
Plug the cable that used to plug into the lighter into the connection circled in yellow.
Plug the connector circled in orange into the back of the lighter.
Now, connect the box with the big plug to the orange connector shown by the blue line.
Now let me explain the green connections cause the pics aren't clear enough to determine which is male and which is female.
Basically, you will have two males and two females here. I dont know if they are the same connector or not. BUT basically what you need to do is this.
Connect one side of the little u with the green circles and the clear connector to the splitter with the yellow and white circles using the green connection. (these should line up male / female). The other end of that u connects to the connector at the top circled in green.
Basically what this is doing is looping the positive through that filter.
Now you see that box, with the black wire with the metal spade connector sticking out of it. That metal spade connector has to be attached to any bolt behind the dash that shows continuity to chassis ground.
Lastly, the purple connections go to the screens.
I hope I explained this ok but any questions feel free to ask.
Take care,
George
The following 2 users liked this post by androulakis:
bens (02-10-2011), nalleyjagparts (02-10-2011)
Old 02-10-2011, 02:44 AM
bens's Avatar
George your a star, can't wait to try this, just need some time at weekend, why carn't Jaguar make it look this easy, will keep you Informed how I go.
Regards Steve
Old 02-10-2011, 08:00 AM
nalleyjagparts's Avatar
Former Sponsor
George = da man.
Old 02-14-2011, 11:01 AM
Atonyrich's Avatar
Hi brought the rear connectivity kit for my S Type 2004, headrests with dvd screens & all the wirering looms, Instructions are not that clear where everything connects in too, has any body done this or is it best to have them fitted.
Regards Steve
__________________
Jaguar S Type 4.2 SE V8:2004
Hi
As you are based in the UK do you have any details regarding anyone who has stock off this kit as I have no luck at present
Regards
Tony
  #28
Old 02-19-2011, 04:41 PM
bens's Avatar
Sorry I took so long to reply working hard, Sturgess of Leicester are selling the whole kit for £149, have a look on there web site.
Regards Steve
Atonyrich (02-21-2011)
Old 02-19-2011, 07:18 PM
joycesjag's Avatar
Received 1,703 Likes on 1,211 Posts
Originally Posted by nalleyjagparts
George = da man.
Yes he is in more than one way! WTG George, yet another brillant post!
  #30
Old 02-20-2011, 12:48 PM
bens's Avatar
Default Photo's of dvds installed
All thanks to George.
Regards Steve
Attached Thumbnails Is this a DIY job or best to have fitted?-100_1258%5B1%5D.jpg   Is this a DIY job or best to have fitted?-100_1260%5B1%5D.jpg   Is this a DIY job or best to have fitted?-100_1261%5B1%5D.jpg   Is this a DIY job or best to have fitted?-100_1262%5B1%5D.jpg
  #31
Old 02-20-2011, 01:52 PM
Regards Steve
Thanks Guys!
Glad to see it all worked out
Bens,
How big are those monitors? The USA version of the system gives us larger headrests and 7" monitors. Plus it plays media off of an SD card.
Take care,
George
  #32
Old 02-20-2011, 03:28 PM
bens's Avatar
See the USA get all the best stuff, Ours are only 5.6" widescreen flat panel displays and no sd card reader, I am going to buy a portable dvd with sd and usb, unless you have any idea's.
Regards Steve
  #33
Old 02-20-2011, 03:33 PM
Nah that's about all you can do. Unless you were to swap it for a USA system.
I know Dan at Nalley wont ship across the pond, BUT other friendly people here might
Have a read here:
https://www.jaguarforums.com/forum/s...ad.php?t=43647
I bet you could have the system, reshipped via an intermediary for less then the 149 pounds you are into the UK system for
One thing I would have done in your car. I would have Vinyl Dyed that control panel cover etc to match your interior.
http://www.summitracing.com/parts/VHT-SP944/?rtype=10
Go on my blog about my 500sl (link in my signature), and read about "making" blue interior parts.
Take care,
George
  #34
Old 02-20-2011, 04:05 PM
bens's Avatar
I thought that, they only give you that colour choice for the control panel cover, yet you can pick your colour to match your interior on the headrests, might have a go at that george, if I can match the colour.
Regards Steve
  #35
Old 02-20-2011, 04:12 PM
Regards Steve
Can you get it perfect? probably not.
Can you get it to where it's a lot more aesthetically pleasing to the eye and fades into the interior, absolutely.
Take painters tape and mask off the entire interior section of the control panel, also mask off the rear section and any holes / connection ports. You are probably going to have to spray it open and closed to get everything exposed covered.
SEM and VHT make the products you want to use.
Have a look at the procedure:
http://www.youtube.com/watch?v=2mMYl2sW0Zw
This is from a camaro / trans am website, but it documents the procedure well.
Take care,
George
  #36
Old 02-22-2011, 03:11 PM
bens's Avatar
Default Just a thought!
The USA system is different from the UK one, but is there any difference in the wireing, because I would like a SD card reader, so if I could get a USA AV panel would this fit?, or is it the built in dvd that picks the reader up.
Regards Steve
  #37
Old 02-22-2011, 03:29 PM
Regards Steve
The wiring is a little different, our power filter is in another place.
The USA control panel has the card reader built in. It only works with up to 2gb SD cards, non SDHC., there is no dvd in the USA system. I'm not 100% certain all the connections are the same. They do appear to be, but the monitors may not be setup to handle 3 inputs like our systems have.
Ours turn on on the card reader setting:
First press of source gives you video 1 (first set of A/V jacks)
Second press gives you video 2 (second set of A/V Jacks)
Etc.
I'd need a really detailed close up pic of the harness that plugs into the control panel and the wiring coming off of it to even being to try to see if it is interchangeable.
Take care,
George
  #38
Old 02-22-2011, 04:01 PM
bens's Avatar
Will see if I can get a picture for you, wonder if it would be worth all the problem, or just stick to a portable dvd with SD card reader and USB, so what dvd do you feed your system with , thats if you can just get the USA A/V panel.
Regards Steve
  #39
Old 02-22-2011, 04:21 PM
Regards Steve
Oh, my car isn't stock at all audio / video wise.
I have a pioneer Double Din / DVD/ NAV mp3 / ipod control head unit.... My video 1 source on the headrests is connected to that.
Take care,
George
  #40
Old 02-23-2011, 05:19 PM
bens's Avatar
Looks great george, how much would that set up cost, and how hard would it be to install?.
Regards Steve
Quick Reply: Is this a DIY job or best to have fitted?
