do i really need to run premium unleaded fuel?
Received 2,263 Likes
Short answer ..... no Long answer......no
The only time the engine 'needs' high octane fuel is in the presence of pre-ignition/detonation/pinging. This occurs most often under conditions of high load/low RPM. If the engine senses pre-ignition/detonation/pinging, the ignition timing advance is temporarily reduced and no mechanical harm is done. Under these temporary conditions, fuel consumption is marginally increased and engine output (power) is likewise reduced. A conservative driver would probably never notice any difference.
There is a myth that lower octane gas also contains insufficient amounts of other additives needed for injector cleaning etc, but there is no hard evidence I've seen to back that up.
sedakai (04-03-2011)
Why would you want to run a lower octane fuel? Sure the PCM can adjust for it, but just because you can, does that make it the correct thing to do? It amazes me where people try to cut corners to save a buck.
We all have jag's stated minimum octane. Why do they state a minimum if it's OK to ignore it?
Like I said in the post back in June the 3 or 4 bucks you save on the fill up it gonna go right back in the tank when you MPG's suffer and you are filling up more often cause your ECU is reconfiguring for the lower octane and in all actualality you are getting worse MPG. Tested this in my Audi A8 I used to have and running 89 got me worse MPG's then running 92. I cant remember what it came out to be but it really wasnt worth the savings of running 89 octane (dropped that 3 or 4 bucks to maybe a dollar) especially when you look at the power loss.
As stated earlier, if a driver is not heavy with the right foot, it would probably make no real world difference to either power level availability or fuel consumption.
From the handbook:
Use only Premium unleaded gasoline with a minimum anti-knock index (AKI) of 91. Using unleaded fuel with a lower AKI than recommended can cause persistent, heavy `spark knock' (a metallic rapping noise). If severe, this can lead to engine damage. If a heavy `spark knock' is detected even when using fuel of the recommended octane rating, or if you hear steady `spark knock' while holding a steady speed on level roads consult a Jaguar Retailer to have the problem corrected. Failure to do so is misuse of the vehicle, for which Jaguar Cars Limited, is not responsible. However, occasional light `spark knock' for a short time while accelerating or driving up hill, may occur.
That doesn't appear to me to be consistent with using lower octane but depends on how you interpret it, whether you think/hope the PCM adapts OK, etc, I suppose.
The octane rating is essentially the rating for the fuel's volatility. A lower octane fuel is less stable than a higher octane fuel.
Jaguar's recommendation that premium fuel be used is to prevent pre-ignition and detonation. Pre-ignition occurs when fuel in the cylinder starts burning prior to the spark due to high heat, which is often attributable to a carbon deposit that is retaining more heat or a number of other "hot spots" in the combustion chamber. A lower octane fuel is more susceptible to pre-ignition because it is more volatile than a higher octane fuel. Pre-ignition results in two separate flame fronts running into each other, one from the spark, and one from the unintended ignition source. When the two fronts collide, it's with great force and the result is an audible explosion we may be referred to as a "ping."
Under the right circumstances, pre-ignition can advance into detonation which is a severe knock that is much more damaging than lighter pre-ignition. Detonation is a very uncontrolled explosion and it can be very destructive to your engine components.
http://en.wikipedia.org/wiki/Octane_rating
A richer fuel mixture (which will help cool the air/fuel mixture), and a less advanced spark will help mitigate the intensity of the two flame fronts that occur during pre-ignition. A "richer" fuel mixture is the key there. If using a lower octane fuel results in your engine pinging or knocking, the anti-knock sensors in the engine will richen the fuel mixture and reduce timing. The richer fuel mixture will cost you fuel economy. The later timing will result in lower cylinder pressure and a corresponding reduction of torque at all rpms (which will reduce your horsepower).
If your engine doesn't sense any pre-ignition, you won't see the hit in power or fuel economy, but Jaguar set their rating because they're assuming you will need the extra octane rating.
From the handbook:
That's how I interpret it.... So, yes, they call for it, run premium. It's 20 cents a gallon more here. That is exactly $3 more per 15 gallon fill.. Hmmm at current prices... $43.35 vs $46.35.... Easy choice..
didnt mean to cause an argument but here it can be anywhere from 20 to 40 cents off and i was just wondering what the actual effects would be, like im not going to destroy the engine if i try mid grade right? and if i dont hear any pings its not causing any damage? or is their build up or something like that. Im just at a loss because i drive 10.2 miles to school and 10.2 miles home and its costing 50 or 60 for gas a week (i think need to check receipt)
![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
kristinaclevenger (04-13-2011)
