Do you stop using premium fuel at $4 gallon? $5?
#121
Hi Harry-
Thanks for your comments on the octane subject.
There's no need to add anything to the gas, it's already got all the detergents required. High compression engines don't produce any more deposits or clog up fuel injections systems any more than low compression engines.
I keep going back to the VVT and electronic spark adv/retard.
I remember reading a study one time that said that most folks would buy premium WHEN they had the extra money (good economy) because of a false sense that it cleaned out the engine - not because the car required premium.
Then again, I do have a few cars (older Buicks) that WILL knock if I don't run high test.
Robert
P.S. Noticed I used high octane, premium and high test just to confuse the point. LOL.
#124
I'm not commenting on the supercharged vehicles here but I use an old school receipt. 1/2 premium and 1/2 regular. I've never had issues with any engines and many I ran hard well over 100k that includes a C5. I don't know for sure but I figure 1/2 premium works like octane boost and boosts the regular gas octane up.
#125
#126
I do know of one Exxon (family owned) station here that caters to the smaller (towed) boat crowd that has a mid-grade that is ethanol free. It is more expensive than the high test.
#127
This is for real? I always assumed they made a "Mid-grade" that was held in different tanks?
#128
We have two tank and three tank filing station here too, but either way there's no benefit in doing a manual half-and-half mix.
The much revered Sunoco 260 of the '60s and '70s was drawn 100% from the high octane tank. The Sunoco 190 was 100% from the low octane tank. The 200, 210, 220, 240 etc. were mixed inside the pump in various ratios. That's what the selector dial on the side did.
#129
#130
If you want to run mid-grade [89 Octane] and the pump only has 87 and 93, well then yes, mix your own. It's the same thing.
I'll let Mikey jump up and down over the debatable benefits of various additives sold by retailers to dump down the filler tube.....
Have fun with that.....
#131
If you're doing your own mix and the station sells (let's say) 87 and 91 AKI, a half tank of each will give you a net of around 89 AKI. Jaguar states that the car would like a diet of 91 AKI please, so you're already two points down. The only incentive to do that is to save a bit of money.
The octane boost in cans is a different animal. Many or most actually do nothing in terms of raising the octane level, the ones that do raise it require huge volumes to make much difference. When the can says 'raises octane by one point' it means that it increase octane by .1, not 1.0. This means that if you fill your tank with 87 and pour in a full can of additive, your fuel is now 87.1 AKI. Not cost effective.
On the other hand, many believe that the octane rating of gas/petrol is also tied to other attributes, most commonly 'engine cleaning' or 'more energy' or 'cleaner running' or, or, or. All of these are false.
Can I start ranting now please?
#133
#135
When I was younger everyone talked about the Amoco 93 or 94 (?) being the "best" gas. As the Amocos went away it switched to BP. Now people seem to like buying Hess because it is made from USA oil more than other brands.
Oh, and this is funny, there were stories when I was in high school that actually mixing the lowest octane with the highest gave a octane HIGHER than the highest octane! Never made sense but people did it all the time.
Kinda like that story that says if you fill you ice trays with warm water they freeze quicker. Funny.
#136
From wikipedia:
The company has exploration and production operations in the United States, United Kingdom, Norway, Denmark, Russia, Equatorial Guinea, Algeria, Libya, Gabon, Egypt, Ghana, the Joint Development Area of Malaysia and Thailand, Indonesia, Thailand, Azerbaijan, Australia, Brazil, and St. Lucia.
Pretty much the same as every other oil company.
#137
+1 on JOsworth's comments, but I'm curious as to what benefits you're expecting from either doing your own mix (vs. letting the pump do it for you), or from cans of additive?
I thought that mixing the different levels would bring the level up to 91.
#138
For the record I've only put premium in the Jag to date.
I do know that you can use lower octane and the knock sensors will decrease power in order to reduce detonation. I think it retards the timing so that you don't damage the motor.
#139
another thing people dont realize (it may or may not have been mentioned in the past 7 pages)
using lower octane than recommended also kinda reduces MPG.....which means you're getting worse fuel economy and filling up enough times to offset those few dollars you originally saved.
now does it sound worth it?
#140
