Does anyone know where the crankshaft sensor is located on a 2004 s type v6
Welcome to the forums adamsavey,
I've moved your question from General Tech Help to S-Type forum. This is the place to post technical questions about your model.
JagV8 (07-06-2019)
The CKPS is on the right forward side of the engine block. The electrical connector is shown on page 40 of the S-Type powertrain into booklet S-Type POWERTRAIN_JJM101517-92.pdf
Crankshaft Position (CKP) Sensor
Crankshaft position and rotational speed are
sensed from a steel timing ring keyed to the front
end of the crankshaft immediately behind the
front cover. The timing ring has 36-1 teeth, ie one
missing tooth, which are angled slightly forward
and bent at right angles to provide a sensing area
for the inductive sensor. The sensor is positioned
in the front cover, to the side of the crankshaft
damper, at approximately 20 degrees to the plane of the
timing ring.
timing ring.
S-Type Owner (07-09-2019)
muttony
04-07-2019 10:30 PM
XiZ
02-04-2017 09:02 PM
Carlos Mijares
11-02-2016 03:10 PM
JessN16
06-12-2016 06:04 PM
