Does anyone need help S-Type!?
Here is the work I have done, if anyone needs help I would be glad to pass it on. I have received a lot of help here myself. (2000-Jag-S Type-3.0) If I have not listed what your looking for feel free to message me and ask.
1. Intake manifold gaskets and valve cover gaskets.
2. Spark plugs and coil packs (all 6).
3. 2 din aftermarket stereo install.
4. New shocks (all 4).
5. Replaced both catalytic converters.
6. control arms, tie rods and so on.
7. Door panels and misc. trim replacements.
2001 stereo upgrade
HI there. I'm interested in #3 the double din modern stereo, gps and navigation unit. My 2001 S type 4.0 is pre the cat 5 cable stuff as in the 2003 and later I believe. I would appreciate any insight and what your running currently. By the way were I phone users if that makes a difference. Thanks John
IvysMommy (01-09-2020)
Hi Gillian
The 2 links directly below give the parts from the UK. If you just google the part numbers, you will get more part options.
I have not had to do this repair.
Jaguar ACTUATOR FOR FUEL FILLER RELEASE - XR857532
Jaguar FUEL FILLER BOWL HOUSING - XR851823
This link has information and photos of a repair with part numbers.
S Type fuel filler cap repair How-To
Finally, this link below is a discussion on the forum on your problem.
https://www.jaguarforums.com/forum/s...r-latch-18066/
Good luck
Paul
Good luck
Paul
Hi,
I have the same 2000 Jag S-Type 3.0 with about 95,000 miles on her. I'm getting DTC codes of P0171 and P0174.
Have you had similar Check Engine Light issues. I'm hoping the problem is fuel or sensors and not injectors.
I'm new to this forum(and forums in general) so not sure where to look for a reply. I've added my email if that is easier: richardinseattle@gmail.com
Thanks, Richard
Thanks, Richard
Photobones (03-08-2023)
