Does the coolant fluid need to be flushed? Help!!!!
To answer your questions... yes on coolant flush and yes on coolant bleed. Look into upgrading the plastic crap thermostat housing with the aluminum upgrade - I guarantee you once you open up that thermostat housing you will find the plastic brittle and cracked for starters...
