Does K&N Filter increase performance?
Received 2,190 Likes
Brutal,
So now some new Jag owners with dual air filters have to make certain they obtain and install two filter elements that were manufactured on the same day? Sheesh, this is getting ridiculous....
Wonder what's next? Maybe having to thoroughly wipe your feet, painstakingly clean the interior of the windshield, and verbally wish your Jag a hearty good day before it will start up first thing in the morning....
I miss the cars of the 1960s more and more with each passing year....
My butt dyno is not very calibrated... The ear dyno on the GMC Yukon XL sure likes the sound of the Airaid set up, but I have not dyno'd it...
no, single stage, but I have it controlled by the Accel super ram Ecu and I can set its on/off time based on rpm and TPS with my laptop. and power levels are set will jet for NOS and fuel. it makes for a very surprising 5500# yellow brick at over 650hp with the 300 shot jets in place. And I welded bungs into the side and tapped them for the fogger nozzles, and theyre dirrectly over each port in the plenum.
Back to your regularly scheduled K&N thread.
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
I run K&N filter in everything from the race car(not pictured with the 9" tall K&N), to the Suburban, the Jag and the custom 400hp engine build I just did on the Nissan truck. 10-20hp is not uncommon for a COLD AIR INTAKE kit with K&N filter. It does give better filtration and performance, but youre not gonna feel the performance increase from even the most calibrated butt dyno, it just not enough. But you have to ask yourself, is the money worth it for synthetic oil? hipo tires, brakes, exhaust, heck if you look at the costs of a Jaguar, you can buy a couple other cars for the price. Ive never ever seen an issue with MAFS is the filter is maintained properly(not over oiled) you can also use dry ones as well. That being said, on the new Jaguars with DUAL air filters, we are seeing issues with cold start running and idle because the OEM filter are manufactured on different days. The filter media has a slightly different flow imbalance which is causing MAFS imbalances from side to side, so on these I wouldnt recommend. The fix is installing OEM in matched sets that have the same day of manufacture stamped on the sides. Otherwise I use K&N's in everything.
![](http://i208.photobucket.com/albums/bb20/brutal2005/SUBURBAN/P8070064.jpg)
![](http://i208.photobucket.com/albums/bb20/brutal2005/SUBURBAN/P2230011.jpg)
![](http://i208.photobucket.com/albums/bb20/brutal2005/PA240006.jpg)
Hi Brutal,
Those are some damn fine engines! I'm guessing the V6 is the peewee of the bunch at a mere 400 hp
![Icon Drool](https://www.jaguarforums.com/forum/images/smilies/icon_drool.gif)
aholbro1
08-05-2021 05:02 AM
Aus V8S
11-13-2015 11:01 AM
