Door lock/unlock on it's own
Old 08-18-2022 | 05:29 PM
Dwayne Mason's Avatar
Default Door lock/unlock on it's own
I have a 2007 Jaguar STR. I am having a problem locking the door. Can anyone provide some knowledge as to why when locking the door it inlocks on it's own. I have manually tried to lock the door with the key but for some reason it doesn't fit in the key hole. My mechanic scanned the car and was unable to figure out the problem. Does anyone have a clue as to why this is happening?
Old 08-18-2022 | 06:37 PM
S-Type Owner's Avatar
This is typically caused by a failed lock actuator, which "bounces back" and fails to send the proper signal to the car's security system indicating all doors are locked; the system fails to set and executes a global unlock.
if you watch the interior lock tabs when locking from the fob, you will see the offending lock bounce back first, then followed by the others.
kr98664 (08-18-2022)
Old 08-18-2022 | 08:51 PM
so most likely the lock that bounces back first is what needs to be replace with a new acutator?
Old 08-18-2022 | 09:29 PM
scottjh9's Avatar
yes it will bounce back very fast compared to the others. 2 things. Use genuine jaguar or orm actutors and get some of these. Ebay item 313441533586. Or the more expensive oem ones if needed quicker
S-Type Owner (08-19-2022)
Old 08-22-2022 | 01:33 PM
Thank you for your insight and help. God bless
Cass3958
08-25-2021 12:30 PM
KayScotts
03-09-2016 04:20 PM
TinRoofRusted
12-30-2014 05:34 AM
Azcat
06-17-2014 12:11 PM
MAC93XJ6VP
XJ40 ( XJ81 )
01-07-2011 05:47 AM
Quick Reply: Door lock/unlock on it's own
