Door speaker install questions
Hi guys. I am about to install new speakers in the doors of the car. There are 4 wires going into each stock alpine speaker. I guess I could do trial and error, but does anyone have any idea which ones are for the tweeter? For instance are the top two tweeter or bottom two, ect.? Any help would be appreciated.
I've been taking a bunch of photos so I'll toss them into the gallery once done. I installed a bunch of edead 45 (similar to dynamat) on the inner door and on the inner door skin.
hey guys. I was playing with the wires. I tried hooking up different combinations of the wires and on both of them the mid bass was coming through. It was my impression that the signals were already supposed to be crossed over coming out of the amp. Anyhow, it seems that like no matter what pair of wires I hook up, there is still pretty strong bass out of the woofer. Anyone have any iput on this?
You have the same as i do, you have the premium sound correct??? If so look at the premium diagram.
NOW just because it may be crossedover, doesnt mean you can in theory run them without the crossovers they came with.......you have to know the specs of the speakers and what they can handle. On vehicles like ours, i would recommend to people the bi-ampable components even though they were more money, because they had a mid and tweet input. Yes you could run into shelving issues with the x-over, but you never had to sacrifice on the input side. It would make more sense if i could tell it/show it in person.
In the rear they are run in parallel and they use a filter capacitor on the back of the tweeter to "cross over" the tweeter" The midbass actually runs full range.
Just wire that input to the input of the passive crossover on that came with the component set. And then wire from the passive crossover to the mid and tweet.
I haven't done chris's front doors yet - between the weather being too damn hot, traveling, my work etc we just havent found the time. I still have his speaker adapters and JL components sitting in my garage collecting dust
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
Take care,
George
Also the volume out of the rear speakers is so low. The fanatic q is a massive driver so I know it's not going to be as efficient. Are our stock speakers 2 ohm? I'm thinking that may be a contributing factor to the low volume as well.
Thanks for the advice to use the tweeter crossover in the rear. That solved my question
The Alpine speakers are actually pretty damn good. I have them running off of a JL Audio XD 400/4 with JL Audio passive crossovers in the front and they sound surprisingly good. Sadly, I think (but never confirmed this 100%) that you have to swap out the source unit in order to replace the amp. Chris swapped out everything all at once so it wasn't an issue for us.
Take care,
George
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
