Doors wont lock with key or fob (manually or remote)
Hello all,
Essentially, my car WILL NOT lock using my key fob remotely or manually when I enter the key into the exterior of the driver side door.
I did some experimenting and my key fob WILL:
-Remotely unlock doors
-Remotely unlock my trunk
My key WILL:
-Manually open my trunk
-Turn on my car
My car will lock if I am inside of it and I lock it manually.
After doing a search I wonder if anyone has experienced the same thing I am currently going through. I have found many threads of folks having the key fob issue but none that I read also have the person unable to lock the doors manually.
Any help would be greatly appreciated as I havent been able to lock my doors in a month :/
My key WILL:
-Turn on my car
goldenstitch,
Although you don't mention it, I presume this is your 2004 S-Type and have therefore moved your question from General Tech Help to S-Type forum. Members here with the same model will be able to help.
goldenstitch (08-31-2016)
goldenstitch,
You are correct in stating this is for my 2004 Jaguar S Type 4.2L
1)What is R&R? (I assume it is not rest & relaxation)
2)If it was the actuator, then shouldn't it not lock at all? Right now I can lock it from the inside but no other way.
Thanks for the reply!
2) How are you locking from inside the vehicle? All 4 doors or 1 at a time manually or with dash power lock button? Are all doors locking, have you walked around and tried each door from the exterior?
I am locking the car once I am inside the vehicle. I guess it is the "normal way" by pushing the lock trigger on the driver's side door
That's what I thought.
Sitting inside, all doors closed. Push the central power lock button. Watch listen to all manual chrome locks (again inside). One of them will lock or act as if it locked then automatically unlock itself. That my friend will be the lock actuator that needs to be Replaced & Repaired.
Cross your fingers that it is one of the front actuators!
Copy and paste in address bar:
https://www.jaguarforums.com/forum/s-type-s-type-r-supercharged-v8-x200-15/rear-door-lock-actuator-fix-w-pics-faq-65657/
https://www.jaguarforums.com/forum/s...ics-faq-65657/
I also tried the key in the driver's side door one more time and...nothing. It neither allows me to lock or unlock the door.
Does this still support the actuator theory?
So, I locked myself inside my car using the main power lock on the drivers side and none of them unlocked themselves. Then I lowered the windows, escaped the car, locked my doors, waited....waited....waited....then went to each door and all of them were still locked.
I suspect your inability to lock/unlock the door with your key is unrelated to your other issue. If you don't use it regularly, the lock will seize and become inoperative via the key. "Regularly" as used herein is defined in very "Clintonesque" fashion: For my 2003, it means every 2 or 3 months. For my 2005, it means stand at the door and work the lock.....because if you walk away for as little as 15 min or so, it will seize again. I use liquid Teflon to free it up.
I don't plan to study the wire-diagrams closely enough until this problem presents itself in one of mine....but you may want to research whether a broken wire in the driver-door-to-cabin harness could cause this problem?
As a workaround...rather than leaving it unsecured, can you not lock it with the drivers' door button with the door open as you step out, then unlock with the FOB?
So this kinda reads like you crawled out a window....but I'm guessing your driver's door unlocks when you pull the handle? (if so, does it unlock the rest of the doors at the same time?) And you stepped out properly then reached in and locked the car via the driver's door-mounted lock-button?
Does your key insert fully into the lock and turn nearly 1/4 turn?
Unfortunately, the workaround will not work for me. If I lock the door using the interior lock while the door is open, it will unlock all my doors immediately afterwards. This is why I need to lower my window for my experiments. I believe this is a safety mechanism so that you do not leave your keys in your car.
