doors won't lock with remote
2000 s type - my doors always locked and unlocked with both remote and key in door. i installed a new battery and the anti-theft security system would not let me start the car. I researched how to reset and found this: lock doors from inside, unlock door from outside with key and start car. I put the drivers side window down, reached in and manually locked the door. i then inserted the key into drivers door and unlocked the doors. i inserted the key in the inition and the car started. Great! But since I did this, the remote will not lock the doors. when I click the remote the doors lock and immediately unlock. so i sat in the car and locked the doors with the remote. when i did this i noticed that the passanger and rear doors locked but the drivers side did not. and then the doors unlocked after 2 seconds. i tried it again and when the three doors locked and manually locked the drivers door. then all the doors stayed locked. so i unlocked the doors from the inside and got out. i tried to lock with the remote but the doors still do not stay locked. i have to manually lock with the key. I think is something with the way i locked and locked the doors when trying to get the car to start. Any ideas??
It might be as simple as one of the doors not closed all that way. Might try opening all the doors and slamming them shut including the trunk. Had a similar problem with my car and I think it was a dirty door sensor. I sprayed the driver door latch with some electrical cleaner to get it to work better.
jaguarlady03 (01-23-2013)
thanks for the info. however, the doors work fine. it's only since i locked the drivers door manually from the inside and then unlocked the drivers door from the outside with the key. it's definitely something to do with that and the way the remote now behaves. maybe i will take the battery cables off again and try to start without locking the drivers side first
thanks again
thanks again
To do a hard (master) reset disconnect the battery earth lead and hold the lead on the battery positive post for ten seconds. When you reconnect the earth lead do so cleanly, don't dither.
Remember - if you need and don't have a radio security code you're in trouble. (very few US Jaguars are fitted with a coded radio)
What this does:
Resets ECM defaults including fuel trims
Resets many other electronic modules
What it doesn't do:
Erase any module programming (re-flashes etc)
What this does:
What it doesn't do:
jaguarlady03 (01-28-2013)
i reconnected my battery and car went into anti-theft mode. with key in ignition trying to start - it wouldn't and alarm sounded. i received an suggestion to lock drivers door from the inside, then disconnect battery and wait 10 minutes. then reconnect battery and unlock drivers door with key. i followed that suggestion and the car did start with no prob. BUT since i did that, the drivers door does not respond to the key fob. there is a click inside the door at the actuator. the three other door locks but unlock with a second because the drivers door wont lock. any suggestions? the sequence i followed seems to have messed with the signal to the drivers door.
jaguarlady03 (01-31-2013)
jaguarlady, I have to agree with JagV8 above.
It may be coincidental that your actuator failed at the same time you had the battery replaced (post #1).
If you read the link I have attached below. We had a similiar problem with the locks (nothing to do with the battery). From what I know, if a door lock actuator fails (as ours did) the computer will lock doors (via key FOB) then a few seconds later unlock them, must be a saftey type thing(?). I replaced our bad actuator (not a job for the timid) and that solved our automatic lock/unlock issue.
https://www.jaguarforums.com/forum/s...ics-faq-65657/
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
kabs3012
09-12-2015 10:40 AM
