drilled and grooved discs advice
Hi all
I'm looking to replace the discs and pads on the my s type 4.0.
Mtech Brakes are selling a full set of grooved an drilled discs, with mintex pads for £180, which is really good value. But I wanted to know if anyone else had any experience with this type of setup? Are there any advantages/dis-advantages?
With the s type being a heavy car and auto, i find i am on the brakes a lot more than with a manual, so my opinion is they will help keep the discs a bit cooler, since they do get really hot some days....
what do you guys reckon?
cheers
cheers
Jumpin' Jag Flash (03-23-2015)
We only say it because it's good advice. These cars have been around for years and practically everything about them has been discussed on the forum already, sometimes by knowledgeable members who no longer contribute to the forum. You miss their valuable advice if you don't search for it first.
Search also saves existing members the aggravation of having to repeat themselves on topics that have already been covered in detail. Even worse - you alienate them by demonstrating that you'd rather ask someone else for help rather than help yourself.
Again, familiarize yourself with Advanced Search. It will be your best friend on the Jag Forum. If you still can't find an answer, don't hesitate to ask your questions. There are some extremely knowledgeable members who will be eager to help.
Cheers!
Cheers!
A good quality oem set up is plenty good enough.
Having done the rear brakes recently I should share a couple of points.
1. rent or buy brake caliper retraction tool. Integrated parking brake require turning the piston clockwise to screw it back in.
2. when retracting the piston, have bleeder connected and bleeder screw loosened 1/2 turn to discharge old fluid. Don't let the old fluid go back into the hydraulic circuit.
3. do not install grooved or slotted discs. I had them on my last car, X-Type, and made noticeable swoosh, swoosh sound at parking lot speed with no change in braking performance.
Jumpin' Jag Flash (03-26-2015)
Woznaldo
09-26-2015 11:02 AM
chatmanx
09-11-2015 07:17 PM
