drivers side mirror replacement
Happy New Year to all. Some SOB took a bat to my drivers side rear view mirror on my 03 S type and tried to knock it off by bashing it forward. Luckily it folded foward and everything stll works exept the glass is cracked and the liquid leaked out Is it possible to replace the glass only and how do you get the thing appart? Thanks, Don
There is an ebay company that sells used mirror glass only. I needed one for my caddy, heated blinker dimmer etc... "bought it now" at $100.00 shipped. I will look for the company.
Removal don't quote me but I believe you use a flat screw driver and pry out the mirror glass, at least on the caddy, and glancing at ours it looks to be the same.
The ebayer I dealt with is flip-it-quick I just checked they have no Jaguar mirrors listed you may want to message them and see if they can locate one. Good luck.
Or I just did an ebay search, there are a few listed: http://shop.ebay.com/i.html?_nkw=Jag....c0.m270.l1313
Apply light pressure to the exterior mirror glass.
Detach the exterior mirror glass.
Apply light pressure to the inner edge of the exterior mirror glass.
Remove the exterior mirror glass.
Disconnect the electrical connectors.
To install, reverse the removal procedure.
I'll try to get the pictograms for you. Depends if you have the electrochromic and want to retain them. Think I saw a bunch of eBay for $56, mostly right side but left side can be found. However, if you want the electrochromic auto-dim, heated whatever.....$200+ and dealer is the only option I found.
Don R (01-15-2011)
Aha! Jag have some help:
This http://topix.jaguar.jlrext.com/topix...document/61728
is actually a PDF (rename it)
More here: http://topix.jaguar.jlrext.com/topix...document/98417
also a PDF
also a PDF
