Drivetrain Vibration.
I bought my car 4 years ago with 14K on it and in wonderful condition.
I did run the speed up a bit on the way home from Atlanta so maybe 110 for a burst once in a while.
As I settled into the normal dreary driving here in the greater NYC area I began to notice that anytime I hit a short burst of 90 (so easy to do) then as I backed off I would get a humming drone sound out of the car until it went back down to 80.
I thought maybe a tire balance or tread issue was the reason but it happens so infrequently because basically you cannot drive over 80 here or risk being slapped severely.
Last fall I got 4 mew Continental DW tires and as they were new they were so much better in response, noise and grip.
But I still have that GD drone. I actually feel absolutely nothing.
There's very little reason for me to have driveshaft issues or even differential issues on a car with only 40K miles unless ... this is a known defect.
So all you swamis of the cat what typical problem does this remind you of?
In May 2009, a former S-Type owner here reported a similar rear-end whine in his 2005 S-Type 3.0. It only showed up at certain highway speeds, perhaps 60 to 70 mph. The fix turned out to be a new axle assembly and axle housing bushing. His car was still under warranty at the time so Jaguar paid 100% for the repairs. If this is indeed your issue, it could be pricey....
The Jaguar documentation covering this issue is TSB 205003....
Years ago I had a dealer S-Type loaner car that suffered from this whine issue. It was indeed very annoying....
The following 2 users liked this post by JagV8:
Jon89 (08-12-2014),
Jumpin' Jag Flash (08-13-2014)
This noise happens only when you let off after going above 80mph.
I haven't and probably won't try it much above 90 but as soon as you put the gas back on it's gone.
Thinking a bit about this it just might be in the diff.
I guess I better have a test above 100. That's not going to be that easy.
The roads are crowded here and folks DO use their cell phones.
We live in a police state here.
![Icon No](https://www.jaguarforums.com/forum/images/smilies/icon_no.gif)
I don't think I'd repair it. I'd probably go the LSD route. I'm not sure it would even be all that much more money than a dealer repair? I have a somewhat local shop who's done custom diff work for me in the past on my race car and another car so I know he could handle the LSD conversion that's been successfully implemented on here.
Sshenton1975
08-30-2015 09:29 AM
qz39j4
02-19-2009 06:25 PM
