Driving without belly pan
Be too easy if all the same. I am at a loss as to why there is what appears to be an air an inlet in it, but I'm convinced this is the entry route for all the small stones and bits of grit that accumulate inside it. Plus no idea what the slot cut out of the egg shaped dome is, nor why there is a 8mm hole bang in the centre. There must be some reasoning to the shape and design of the thing.
I believe yours was a cleaner version of ours staatsof:
yeah yeah I know, this is what it looked like 2 days after ownership, imagine my surprise when I dropped it to have a looksie at the 189 point inspection from the dealer who sold it to us with leaking oil pan, valve cover and IMT O-rings!
BTW it does not look this way any longer !
That's more like it. Looks very similar.
#30
#31
#32
#33
Bob, did you write that the two plastic bags attached to your belly pan were empty? Interesting...(written with tobacco pipe in one hand and chin held in other) Bob, you may want to sit down before you hear what I write... Someone snatched two kilos from ya?
#34
#35
#36
#38
#40
Does not cover the trans. It ends right where the pan starts but it might help just to get it out of the way when doing. I cant remember if any of the pan bolts are covered by it as I usually take it off anytime I do anything under the vehicle.
