Drooping headlights
Mine basically point at the ground, and it's making it difficult to see at night. Before anyone mentions Brutal's thread:
https://www.jaguarforums.com/forum/s...ype-faq-10745/
I've read over the whole thing and viewed Vance's video. Mine don't really have any play in them. When I start the car at night, I can see the lights auto level, moving up and down. Turning the vertical screw to try and tilt them doesn't seem to do anything though. (which I'm not entirely sure what it would do anyway if they "auto" level).
I'm open to suggestions.
Just a thought.
There is also one on the front suspension.
The headlight levelling module is supplied from ignition switched supply from F16 10A in the primary junction fuse box.
The ride height sensors drive into this module and are not separately fused.
Hope this helps.
Hope this helps.
If you search on here for drooping headlight fix you will find out how to fix it within 10 mins with a drill and 2 screws. I had it happen to me and looked on here. It is a common problem. But to put new HID headlights in is very expensive. I searched on here did just what they said and it has been fine ofr 3 years now.
Fletch44
09-28-2015 02:21 PM
