DSC / ABS / Cruise Not Available....
#61
Mine has a light that flashes if TC is activated (you have to try quite hard on normal roads in an STR to make it happen). Is yours flashing (it'll be brief I expect)?
Assuming (gulp!) the sensors etc are OK now, check the wheels & tyres very carefully in case of lumps, mis-shapes, odd tyre pressures or and I do mean this different size rims or tyres!
#62
#63
Once installed, make sure your charging system is up to snuff. Your car has a smart charging system. Right after engine start, you should see around 14.5V as measured at the battery, tapering off around 13.5 after a few minutes.
Lots more details here about problems caused by low prestart voltage:
https://www.jaguarforums.com/forum/s...attery-193787/
mutu88
12-16-2015 03:10 AM
