DSC fault 2000 S-type
jagfan, normally with the dsc fault, it is caused by a wheel sensor issue. This should also be giving you an ABS error too. Unfortunately, this is going to require taking the car to a shop with a high end code reader. They will need to access the other computers in the car (not just the ECU). This will tell you down to the sensor that is acting up and causing your problem. From there, it will be down to a sensor, a wiring problem, or a computer issue.
Guest
Posts: n/a
