DSC Light flashing
You still didn't post your VIN. The TACM may not exist in your car. Also, if your DSC now needs calibrating you must have a fault, such as wiring, to explain why it needs that. You may well find you can't get data using AE so try it. If you can't it helps you figure out which wires are damaged.
You can read the yaw etc sensors using AE so again you can check.
Thanks for the help.
The steering angle is probably OK. I think they read some value (which looks pretty random) and that is then programmed into the module when it's configured. You could say that it'll be set so -27 is straight ahead and thus other values can be figured out relative to that datum.
I really can't see why your module would need reflashing![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
(Can't hurt to try - apart from maybe your wallet.)
Code says the sensor in the steering wheel ? Will A alignment change this and turn off the light? Got car running been setting for four months. Was A bad computer. I would like to see if I need the sensor or A Alignment car had bump in front driver side. Anyway would like to have my Cruze working.
rsa760041
23
09-25-2015 01:33 PM
