DSC Not Available.
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
Hi, had an S type jag now for a few years and really happy with it. But just had the front brake discs and pads changed to EBC stuff and the brakes are now great but now have no traction control/ dsc. The moment I picked it up from the garage the traction control was not working (snow on ground) but ABS is. No lights come up on the dash straight away but after driving for a while they do come up saying DSC not available. When I asked the mechanic he said he didnt do anything but change the discs and pads. He did just push the brake pistons back slowly he says. Next time I start the car there are no lights on the dash to begin with but soon they will come on again. The traction control/dsc hasnt worked since. Anybody any ideas please.
Hi, had an S type jag now for a few years and really happy with it. But just had the front brake discs and pads changed to EBC stuff and the brakes are now great but now have no traction control/ dsc. The moment I picked it up from the garage the traction control was not working (snow on ground) but ABS is. No lights come up on the dash straight away but after driving for a while they do come up saying DSC not available. When I asked the mechanic he said he didn't do anything but change the discs and pads. He did just push the brake pistons back slowly he says. Next time I start the car there are no lights on the dash to begin with but soon they will come on again. The traction control/dsc hasn't worked since. Anybody any ideas please.
Just a thought, that the mechanic may have disturb the senor or the wiring for the DSC system. If you can check around the front wheel area and make sure there is not a loose or unconnected wire anywhere. Also worth checking that the DSC button is engaged, as some fingers may have been playing with the control buttons etc.
Hope you find the cause soon, as in the weather we have just now it is useful to have the DSC in full working order.
Regards,
Telfer.
Taze1000 (12-04-2010)
One question, was anything done to the rears? As Telfer pointed out, check the front wheel sensors and wires. A flashlight and wheel off should be enough. If it all looks good and plugged in, try spraying the area of the sensors and ring with brake cleaner. Don't use anything else since it may leave a residue that could damage your brakes or the sensors. Also, check your brake fluid level.
If these simple things don't pan out I personally would ask the local dealer to run their scan tool on it and pull up any codes stored by the ABS/DSC system. Remember the basic auto parts store scanner is not going to be able to pick up the Jaguar Specific codes.
Also, if the codes/issues are a result of the work done, I would be sure to start looking for a new service center.
![Icon No](https://www.jaguarforums.com/forum/images/smilies/icon_no.gif)
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
Cheers for the replies already. In reply the car is 2003, 3.0 v6 and auto. The rear brakes had the same brake disk change a while back without any problems at all. Will check around the sensors tomorrow and have a look and hopefully that’s all that will be needed. The button is ok as I tried it when I first noticed it was spinning up well and the dash said it was turning it off and on but it made no difference to the working of the DSC. Used the car tonight and it was still the same as the warning light didn’t come up on the dash for a while. Stopped and started a few times and noticed the light comes on sooner now. Makes it more fun with the weather we are having lol. Just hope the large snow fall doesn’t hit around here soon. Will keep you updated. Cheers.
....Everything you said is great, hope you dont mind me suggesting NOT using Brake Cleaner to spray on sensors and wires is not a Good thing at all!!
Use "Electronic Contact Spray" which you can get at any parts store. Its much better and effective than using Brake CLeaner![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
goges
10-05-2015 04:53 PM
