DSC Not Available, ABS Fault, Transmission Fault - wont start
Started having some issues with my 2005 S Type. Got the DSC Not available, ABS Fault and Transmission Fault - when driving home AC would cycle on and off, then all displays died, but a moment later came back on. Got home, car would not start - half hour later it started. Next day all messages were gone. A couple of days later messages came back - on way home again and all displays died and did not come back on. Got message could not apply parking brake. Next morning started car - would not shift out of park. Switched off, car would not start - hooked up a Jump starter and with the Jump starter hooked up the car would shift out of park. Unhooked Jump starter and car would not shift out of park.
Thanks - was figuring the battery was causing a problem - had it tested on Sunday at batteries plus - they said it was fine - just a little under on the volts - was showing 11 volts give or take. What do you mean about damage from the jump start - and do you think there would be a problem with the alternator?
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
