Dtc activation button ???
I have read on the internet the TRIP button usually starts the DTC readings and usually its a stalk trip button but on my 2000 3.0 V6 the trip button is simply on the dash. If I hold it down and then turn on the ignition, there are no readings or system check:
- So what button do I hold down then?
- Is this hidden DTC menu available on my model?
- what could I be doing wrong?
Thank you for your help.
hi
if your on about the hidden menus on the dash, then have a look here
Jaguar S Type Instrument Cluster Diagnostic codes
cheer
joe
cheer
joe
Designeer (01-07-2018)
Thank you JagV8, it appears I have an early s-type, I will look into the pricing of an OB-II reader.
I have an icarsoft i930 but it is said that it does not work on all cars but it does read all the modules on mine.
I also have autoenginity tool with the enhanced jaguar packet. They were selling the older tool on ebay which they told me would work on cars to 2004. The jaguar enhanced packet is expensive but I find it to be very good.
If you just want to read the engine codes then you can buy an elm 327 I use an usb version as I have found them to be more reliable along with a French programme.
It all depends on how much you are able to work on the car and how much money you want to spend.
Philipintexas
11-04-2016 09:28 AM
Johnken
01-31-2016 01:11 PM
looops
10-03-2014 03:24 PM
vdpnyc
02-07-2011 11:13 PM
