At dyno now (PTuning)
Cambo351,
Thanks for the suggestion as we are all in the same boat in the search for more power.
I searched and read through threads this morning regarding the boring of the throttle body from 75mm to ~80-81mm. I likely missed something since I did not see the cost or dyno results showing this modification is actually worth doing.
I went back to the stock cats because the hi-flow cats failed.
1320racer (10-10-2012)
1320racer, have you done the intake elbow as well? That was dyno proven for 10-12HP
https://www.jaguarforums.com/forum/s...e6/#post519314
Regarding the Maxbore, it's $120 for the service plus shipping (and your time). Even if that only gets you 5HP it's still a cheap mod.
At best, vendors will advertise 'peak' gains, but one glance at the dyno sheet goes to show you those benefits are isolated to mid-range/torque numbers.
1320racer's observations are right on the money when describing his 2.6lb pulley upgrade; he says, "the smaller 2.6 inch pulley helped just a bit when launching but diminished top end horse power...
We can make small gains through efficiency improvements (read: how the motor breathes), otherwise, any substantial gains require pushing MORE AIR, which just isn't going to happen on the already maxed out factory Eaton supercharger.
Same goes for chips/tune's on mostly stock STR's. A/F ratio is a *bit* on the rich side when stock, but the A/F traces on modified dyno sheets appears to have little to no room to lean it out more safely, and even then, gains through A/F tweaks at that point are minimal. Ignition timing is trickier and dependent on fueling too, and the factory computer seems to do a good job optimizing at it as is. Theres no such thing as to keep throwing timing at it and it will keep making more power on a given fuel. Eventually, you hit the 'right' timing profile and that is it.
#30
Larger throttle bodies are a standard aftermarket performance item for other makes, just a few example for Fords;
Mammoth Supercharger
Ford BA-BF V8 Big Mouth Throttle Body Performance Automotive Enhancements
Check the prices from SS Inductions in Oz, $675 for an 80mm TB (stock being 75mm) and Maxbore does it for $120 or so....
#31
#32
#33
#34
Er... wrong, surely? One TB, 2 TPSs. Used for safety. You can see them in the Electrical Guide as TP1 and TP2, in sich as fig 03.5
#35
#36
#37
Don't know, I would say it would be too expensive for what you can get out of the Eaton, as that is your main problem.
The boring out is cheap enough to do and will certainly help a little, but results will depend on how much more airflow you have over stock obvioulsy, and the TB is just part of the intake.
#38
What I was trying to explain, is that the factory TB at 75mm, can be modified to 80mm by Maxbore. That would be the same housing & TPS as original, so no compatibility problems, just more flow.
SS in Australia sells an aftermarket 80mm TB to replace the factory 75mm TB on the V8 Falcons, for $675. So it's an example of why the Maxbore looks like a good value proposition, and that a bigger TB is a sensible modification worth looking into, it is being done on other engines (& it's the next mod on my list).
A bigger TB, along with improved intake elbow (i.e. Qwiketz, Mafioso, etc) is going to be a winning combination.
#39
#40
