Electric intake booster fan
I saw an intake electric fan kit for sale. It was listed under mods for the STR. Does anyone out there have any knowledge about these? It says 20 more HP. I am catching up on needed maintenance from the previous owner's neglect before I jump into any performance mods but this caught my eye.???
The following 2 users liked this post by JagV8:
Life2short (03-26-2013),
police666 (03-22-2013)
Received 2,266 Likes
Thank you all for the info. That's what I love about this forum, No BS. I thought the theory was sound. Taking power from the electrical doesn't effect the egine HP in a negative way so...... Now that I re-look at that little fan and imagine how much it could really push in relation to putting my hand out the window at 59mph (my favotite speed to step on it, it seems to step down into just the right head snapping gear/RPM to make me feel good). What was I thinking? The dyno test says it all. It sounds like the intake mod I read about most is the way to go. (90 degree intake though I often wonder if that octopus stock intake is designed to even out flow) K&M filter, polish intake for better laminar flow. At the same time I need to clean the throttle position sensor and seal it. When the obd says it is at 0, I code every 2 minutes. Seems to happen more when it's wet out. Need to read up alittle more on updated SC pully and the SC oil change has to be good. I was a hydraulic machanic for many years and not only will it break down but over time in a Non-combustion application it can still aquire sedimensts from the closed system. If bad enough it works as a light lapping compound on the componants eventually working them out of specific tolerances and then...Sorry, that's another thread.THANK YOU ALL AGAIN
Received 2,194 Likes
clubairth1
29
05-10-2024 12:57 PM
xjrjag
09-27-2015 01:53 AM
