Electrical problem
Electrical problem
Well its weird all of a sudden the lights went off in the inside of the car not all of them, everything that is suppose to be on during the day works when you turn the lights on for night driving it does not dim the radio display and the air con/heater display, if you press the button the a/c or the dual the light comes on but not the button illumination. The gauges work ,the turn signal work but not the back illumination I check the fuses they are all good and I also check the relays, good as well. I'm telling you its weird. i opened the radio and the heater controls and the led are working but they don't illuminate when you flip the lights on. I disconnected the battery for the night and turn the car on with no change. Any ideas.
99xk8guy
06-05-2023 06:28 AM
