Electronic Park Brake - Pin Out / Wiring details required.
Hi guys,
I've installed a new stereo - a Kenwood DDX-8024BT. This has the ability to play DVDs and video from a USB device, an iPod or an SD card. The only thing is that it will not show the video if the handbrake isn't engaged (there is a signal wire in the stereo wiring adaptor that is supposed to be attached to the handbrake warning light switch). In this case, you get the sound, but a blue screen with a warning that the brake is off.
The problem is, where is the equivalent of the handbrake light switch in the electronic park brake?
Hence the need for the pin out / wiring diagram for the EPB so I can work out which line I need to tap to get the brake signal.
So, if any one can help, please let me know!![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Thanks in advance,
Jason
Thanks in advance,
Jason
Just wire in a toggle switch to ground. That way you can just disable it whenever you want. Or google Kenwood DVD Bypass...
Hi guys,
Thanks in advance,
Jason
Thanks in advance,
Jason
Hi guys,
Thanks in advance,
Jason
Thanks in advance,
Jason
