Electronic Parking Brake 2004 S-type
The following 4 users liked this post by joycesjag:
Received 2,263 Likes
Taking it to a Jag dealer will be an extremely expensive move. If you can't DIY, maybe a good indy would do it.
Are you sure the actuator itself is toast? That's kinda rare.
Location: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
When my EPB motor failed, the car would sound several quick beeps when I extracted the key during shutoff. The motor was loud and made a crunching sound during shutdown too, and I also had some dash messages/lights and beeps when starting the car - all of which indicated some problem with the brakes.
I did some trial and error things and determined that holding the EPB paddle down during shutoff - thereby disabling the EPB - would eliminate the beeps, error messages and crunching noise. I used this procedure during every shutdown for 3 weeks until I finally got it repaired.
My indie mechanic determined that the park brake cables were intact, but the EPB motor had failed, so I bought a new EPB Assembly off eBay for $253 (dealership: $600+) which my indie installed. It now works fine again and no more beeps, dash lights or motor noise.
Here's a link to the part and supplier from whom I bought my new EPB Assembly...
Jaguar 03 08 S-Type Parking Brake Lever C2Z3205 | eBay
Note that this part is for 2003+ non-STR models. Your car may have a different part number, so check JEPC before ordering. It is listed in JEPC under "Braking System/Handbrake Mechanism".
Although rare, the EPB motor does fail, as it did in my case. But the car gave me lots of indicators of the failure. So, if you are hearing beeps or seeing any dash messages during shutoff, then it is possible yours failed same as mine. See if the beeps and messages disappear when you hold down the EPB paddle while extracting your key.
Absent any failure messages or beeps I'd look at the rest of the EPB system for possible failures first. And as always, you should do as much research on this forum and in the Jaguar manuals, which are available as free downloads on this forum.
Jumpin' Jag Flash (10-25-2015)
Many of the original part numbers on these cars have been superceded by newer numbers that are often not listed in JEPC. Gaudin Jaguar Parts is one of several excellent online genuine Jaguar parts sellers that have reliable parts databases you can search for up-to-date part numbers. Once you have the latest part number for your specific car you can then search Amazon, eBay and other parts suppliers to comparison shop. You'd be surprised by the variation in parts prices.
In my case it was pretty easy to tell that it was a motor failure and not the module. The noisy motor operation during shutdown told me the module was working but the motor was failing. My indie confirmed my suspicions and problem was resolved with new motor assembly.
But you make a good point, and there's no substitute for a good, methodical diagnostic approach.
SilverXtype2K2
02-03-2024 06:28 AM
FDR
05-23-2016 09:18 PM
