Emergency brake motor apart:
i am going to do the install tonight, ill try and take pics as much as possible. I will then upload them and link them back to here.
I already removed the other one, and after taking a look at it, it is as simple as changing the brake cables on a pedal bike. And unbolting it from the vehicle.
Quite simple in fact. Laying under there and getting the motor out in one piece is the hard part. lol
We'll see tonight how bad it is to put the motor back in.
![](http://carphotos.cardomain.com/ride_images/3/3436/4749/33589874005_large.jpg)
![](http://carphotos.cardomain.com/ride_images/3/3436/4749/33589874004_large.jpg)
Ok so in the one pic, you can see where the 2 10mm bolts are that hold the EPB in, well after looking at it, there is no way to completely put the new unit in without removing the three silver bolts and dropping the rear pumpkin down about 4 inches. Remove the 2 18mm one in the same area as the 10mm ones, and remove the 16mm from the front of the pumpkin assembly. It is heavy but movable by hand. I used a floorjack to hold it and then let it down till it stopped, once it bottomed out and didnt move, it was then i slid the whole motor up inside and attached the 10mm. Then do the cables, make sure everything is clear, and then i plugged it in. Once this was all done i lifted the pumpkin back into place, do the 18mm bolts first and snug them up, then install the 16mm. once these are all lined up then go back and tighten them.
It really was pretty painless of an install, and i really couldnt get any good pictures of the install as it is in an area that isnt very good for taking pictures.
it is a pity that this is impossible, I have broken only this magnet which is the hall sensor, everything else works
#30
1964Daimler
09-09-2015 11:28 AM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
